Calculating Mass with a Frictionless Pulley: A Physics Problem
  • Thread starter Thread starter koomba
    Pully
The discussion centers on calculating the mass m1 in a physics problem involving a frictionless pulley and two masses, with one mass (M2) accelerating downward. The user initially expresses confusion about the problem but correctly identifies that the acceleration of mass m1 would be -1.10 m/s². A suggested formula for calculating m1 is derived, which relates the masses and acceleration to the gravitational field. After applying the formula, the user confirms that it yields the correct result. The thread highlights the importance of understanding the relationship between acceleration and mass in pulley systems.
koomba
Ok I've been working on this problem for a while, and I'm kinda new to physics, so bear with me. So here it is:
Heres the picture of the problem:
A frictionless pulley with zero mass is attached to the ceiling, in a gravity field of 9.81 m/s2. Mass M2=0.150 kg is being accelerated downward with a=1.10 m/s2. Calculate the mass m1.
Just assume there is no compression/stretching of the rope on this problem. ALso, I guess the acceleration of M1 would be -1.10 m/s^2, correct? Beyond this I'm really confused. Any help would be greatly appreciated! Thanks.
Steven
I suspect a/g = (M2- M1) / (M2 + M1). Then (M2 + M1) a/g = M2 - M1 . and
M1 a/g + M1 = M2 -M2 a/g so M1 = M2 (1-a/g)/(1+a/g) .
I'll see what kind of numbers I get with that, thanks!
Edit: Hey looks like that worked out, thanks man! :biggrin:
