Calculating Minimum Power for Perception of Radiation from a Point Source
The minimum power required for a point source of radiation to be perceived at a distance of 10 meters, given an intensity of 8 x 10-7 W/m2, is calculated using the formula P = I * A. The area A of a sphere is determined by the equation A = 4πr2, leading to a power output of 0.001 Watt, or 1.0 mW when expressed with appropriate significant digits. This calculation confirms the relationship between intensity, area, and power in radiation perception.
  • Understanding of radiation intensity and power calculations
  • Familiarity with spherical geometry and area calculations
  • Basic knowledge of significant figures in scientific notation
  • Concept of point sources in physics
  • Explore the concept of radiation intensity and its applications in physics
  • Learn about the inverse square law in relation to point sources
  • Study significant figures and their importance in scientific calculations
  • Investigate the effects of distance on the perception of radiation
Students and professionals in physics, particularly those studying radiation, acoustics, or any field involving point sources and intensity calculations.
jasmin_89
Power source of radiation
Is my solution correct?
Hallo, can anybody help me and check if i have the right result:
What is the minimum power P that a point source of radiation (I=8*10^(-7) W/m^2) at a distance of l=10 m from the listener must have in order to still be perceived? (Note: The emitted energy per area can be related to a spherical body with A=4 π r^2)
P=I*A
P=8*10^-7 (W/m^2)*4*pi *(10m)^2= 0,001 Watt
:welcome:
Your result looks correct to me.
Small nitpick: If no other constraints are given I would probably write the result as 1.0⋅10-3 W or just 1.0 mW to better signal the number of significant digits in the result.
Ok, thank you :)
