Calculating Net Displacement Using Vectors
  • Thread starter Thread starter skp123
    Vectors
To calculate the bird's net displacement, first break down the flight path into vector components. The bird flies 100m east and then 200m at a 45° angle northwest, which can be resolved into horizontal and vertical components using trigonometric functions. The horizontal displacement combines the eastward distance with the cosine of the northwest vector, while the vertical displacement uses the sine function. A right triangle can then be formed from these displacements, allowing the application of Pythagoras' Theorem to find the net displacement. Visualizing the vectors accurately on graph paper is recommended for clarity.
skp123
A bird flies 100m due east from a tree, then 200m northwest (that is 45° north of west). What is the bird’s
net displacement?
I am looking for the formula , which solve this task. We need to use vectors ,but I don't know the formula.
Well then, forget about formulas. Can you solve it by drawing a picture? (Maybe on graph paper?) After that, we'll talk about the math.
[PLAIN]http://img191.imageshack.us/img191/9901/kokoj.jpg
And now what ? Maybe I needto use this formula S=a*b*cos45
It would be easier for you to visualise if you shift the 200 vector to the other side of the 100 vector. Then, break the 200 vector into horizontal and vertical components.
It will be 200Cos45 horizontal and 200Sin45 vertical.
So your net horizontal displacement will be (100 + 200Cos45) and vertical displacement will be 200Sin45.
Now you've got a right angle triangle of displacements, which you can use Pythagoras' Theorem on to solve for the net displacement.
For one thing, it would help if you make the drawing to scale. So the 100m line should be half the length of the 200m line, and the angle should really be 45 degrees. (And I would not suggest shifting the vectors as Maybe_Memorie suggested, at least not just yet. The point now is for you to be able to see the path of the bird.)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
