Calculating Rolling Motion: Solving for Time on an Incline without Given Mass
The problem involves calculating the time it takes for a spherical object to roll down an incline without slipping. The object has a specified diameter and moment of inertia, but its mass is not given. The incline angle and gravitational acceleration are also provided, and the original poster seeks guidance on how to approach the problem without the mass.
  • Participants discuss identifying forces acting on the object and applying Newton's laws for both translation and rotation. There is mention of substituting variables to relate translational and rotational motion, as well as questions about how to find angular acceleration and time.
Some participants have provided guidance on using energy equations and kinematics to approach the problem. There is an acknowledgment of different methods being explored, but no explicit consensus has been reached regarding the best approach.
The original poster expresses anxiety about an upcoming exam and a desire for clarity on the concepts of moment of inertia and torque. There is a lack of consensus on the necessity of mass in the calculations, with some participants suggesting it may cancel out.
hoseA
A spherical object has a(n) 54.4 m diameter.
Its moment of inertia about a diameter is
I = fMR^2, where M is its mass, R is its
radius, and f = 0.302.
The acceleration of gravity is 9.8 m/s^2
Starting from rest, how long will it take this
object to roll, without slipping, 10.88 m down
an incline that makes an angle of 35.1 degrees with
the horizontal? Answer in units of s.
How does I figure this out without a given mass? Does it cancel out in the calculation?
An approach to this and concepts involved in solving this would help greatly.
I don't know, I don't like moment of interia nor torque. :(
I have my final exam tomorrow, help is greatly needed and much appreciated.
Start by identifying the forces that act on the object. Then apply Newton's 2nd law for both translation and rotation to find the acceleration of the object down the incline. (Since it rolls without slipping, figure out how the translational motion is related to the rotational motion.)
Mgh= 1/2mv^2 + 1/2 Iw^2
I can use v=Rw to substitute into the equation and eventually solve for v.
But then how do I find alpha to solve for t?
w= alpha * t
Newtons second law... F=ma; torque=I(alpha)
alpha = (gsin(theta))/(R + (I/mr))
t came out to be equal to 2.24226 s. (which is correct :smile: )
Thanks to all those that helped!:approve:
Just a correction:
w= alpha * t
dw = alpha * dt
Good luck on your exam.
Thanks... I really need an A. :)
There's nothing wrong with solving the problem this way. Once you solve for the final velocity at the bottom of the incline, you can use simple kinematics to find the time. Hint: What's the average speed of the object as it rolls down the incline?
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 97 ·
