Calculating Temperature Rise in 100m Waterfall: Heat Energy Questions
To calculate the temperature rise in a 100m waterfall, the potential energy (P.E.) of the falling water is converted into heat energy. The equation P.E. = mgh can be used, where g is the acceleration due to gravity (9.8 m/s²) and h is the height (100m). Setting the potential energy equal to the heat energy (Q), the equation becomes M(9.8)(100) = mcΔT. The challenge lies in determining the mass (m) and specific heat capacity (c) of the water, which are necessary to solve for the temperature change (ΔT). Understanding these relationships is crucial for completing the calculation.
shakejuhn
Much of the energy of falling water in a waterfall is converted into heat.
If all the mechanical energy is converted into heat that stays in the water, how much of a rise in temperature occurs in a 100 m waterfall?
q=mc(Tf-Ti)
Q=mc Delta T
Delta T = |Tf-Ti|
i have no idea where to start or what equation to use all i see is the 100m can some one please lead me in the correct direction with the correct formula to use.
potential energy = mgh
This is the energy available to be converted to heat.
ok so P.E.=MGH
P.E. = M(9.8)(100)
is this correct there are still 2 unknows
If all the energy is converted into heat then P.E. = Q
Set them equal and solve for delta T.
ok so the equation would look like this
M(9.8)(100) = mc Delta T
but i still need to know the Mass and MC am i overlooking something??
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
