Calculating the mass of the wheel on a pendulum on a watch
The discussion focuses on calculating the mass of a balance wheel in a watch, which is a thin ring with a radius of 0.95 cm and oscillates at a frequency of 3.10 Hz. The torque applied is 1.1x10-5 Nm, causing a rotation of 45°. The correct mass of the balance wheel is determined to be 0.41 grams, contrasting with the incorrect calculation of 2.04e-4 kg. The user identified a mistake involving the square root of a negative number, which led to the erroneous result.
  • Understanding of rotational dynamics and torque
  • Familiarity with the moment of inertia formula (I=mr2)
  • Knowledge of angular frequency and its relation to oscillation
  • Ability to convert degrees to radians
  • Review the calculation of moment of inertia for different shapes
  • Study the relationship between torque and angular displacement
  • Learn about oscillatory motion and its equations
  • Practice converting between degrees and radians in physics problems
Students studying physics, particularly those focusing on rotational dynamics and oscillatory systems, as well as educators looking for examples of common calculation errors in mechanics.
NathanLeduc1
The balance wheel of a watch is a thin ring of radius 0.95 cm and oscillates with a frequency of 3.10 Hz. If a torque of 1.1x10-5 Nm causes the wheel to rotate 45°, calculate the mass of the balance wheel.
I=mr2
T=(2π)sqrt(I/mgh)
τ=-Kθ
I got an answer but it's wrong...
Here's the work I did:
1.1e-5=-K(pi/2)
K=-7.003e-6
19.5 rad/s = sqrt (7.003e-6/(M(0.0095m)2))
380.25 rad/s2 = 7.003e-6 Nm / 9.025e-5m M
M*0.0343 m/s2 = 7.003e-6 Nm
m = 2.04e-4 kg
The answer should be 0.41g
(I realized just now that I took the square root of a negative number earlier. I tried to redo the problem but I'm still stuck...) Thanks!
I=mr2
T=(2π)sqrt(I/mgh)
τ=-Kθ
1.1e-5=-K(pi/2)
K=-7.003e-6
m = 2.04e-4 kg
Is that the complete problem, word for word.
It seems that some information is missing. I could guess at what's missing, but it would be just a guess.
Yep, that's the question word for word.
What is 45o in radians?
pi/4
Oh my goodness... I just realized why you were asking me that. Wow, I am dumb. Man, those stupid mistakes get me every time. Thanks for the help.
11K
