Calculating the Planck Constant: A Helpful Guide for Physics Students
To calculate the Planck constant, use the photoelectric effect equation KE_max = hf - φ, where φ is the work function and KE_max is the maximum energy of emitted electrons. Rearranging this equation allows you to express it in the form of a straight line, y = mx + c, where h represents the slope. By plotting the data from your experiment, you can determine the value of h. Additional guidance may be needed for those unfamiliar with the concepts. Understanding this process is essential for physics students preparing for tests.
DaltonGR
Hello,
First time at this site really good.
So on to the point.How can i calculate the Planck constant so i can compare it with the already known number for it??its for a physics test and i can't find out ...
Thnx in advance
You can do this with the photoelectric effect. You know the equation KE_{max} = hf - \phi, where \phi is the work function of the metal and KE_{max} is the maximum energy of the emitted electrons. You need to relate that equation to that of a straight line, ie. y = mx + c, then you can calculate a value for h.
Because I am not that good can you help me more.It will save me
thnx
