Calculating the Speed and Acceleration of Jillian's Engagement Ring
The discussion focuses on calculating the speed and acceleration of Jillian's engagement ring thrown from a height of 11.5 meters with an initial speed of 4.95 m/s. Participants emphasize the importance of using the four equations of motion to determine average velocity, average acceleration, and the time it takes for the ring to hit the ground. Key points include the necessity of solving for time and being cautious with negative signs in calculations. The quadratic equation is recommended for finding time solutions, discarding any negative results as they are not physically relevant.
  • Understanding of basic kinematics concepts
  • Familiarity with the four equations of motion
  • Ability to solve quadratic equations
  • Knowledge of vector signs in physics (positive and negative directions)
  • Study the four equations of motion in detail
  • Practice solving quadratic equations in physics contexts
  • Learn about average velocity and average acceleration calculations
  • Explore the effects of gravity on projectile motion
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of motion, particularly in introductory physics courses.
aznriceboiz5
Jillian angrily throws her engagement ring straight up from the roof of a building, a height 11.5 above the ground, with an initial speed of 4.95 . You may ignore air resistance.
For the motion from her hand to the ground, what is the magnitude of the average velocity of the ring?
Isn't avg velocity = x2-x1/t2-t1? if they don't give you t do you have to figure it out? I did but i still got it wrong. It looks to simple from the calculations I have been making. This is my first physics class and its hard :cry:
For the motion from her hand to the ground, what is the magnitude of the average acceleration of the ring?
same with this one
In how many seconds after being thrown does the ring strike the ground?
What is the speed of the ring just before it strikes the ground?
thanks for the help everyone
You have a good start
You have the avg. velocity part right and you need to solve for time.
Hints.
1. What is the avg. acceleration (this is the key to the problem)
2. You can use the 4 eqns. of motion to solve any other question you asked.
3. Be very careful with negative signs. Make up positive and down negative. If you don't your math will be wacked out.
4. When solving for time you will get 2 solutions. ( You may need to use quatdratic equation.) Just ignore the negative time it is not physicaly relevant.
I hope this is a good start.
Thanks curly
  • · Replies 16 ·
11K
