Calculating the strain in three different ways - experimental error?
An experiment was conducted to measure the strain of a channel section beam in bending using a strain gauge and dial gauges for deflection measurements. The strain was calculated through three methods: direct strain gauge readings, deflections (curvature), and experimental stiffness. While the strain calculated from deflections and stiffness showed a maximum error of 10%, the strain gauge readings exhibited a higher error of around 30%. The experimenter confirmed the accuracy of their methodology but is puzzled by the significant discrepancy between experimental and theoretical results. A suggestion was made to ensure that strain calculations align with the orientation of the strain gauge.
Cottontails
I've recently done an experiment where I've obtained the strain of a channel section beam in bending. I used a strain gauge to get the strain from the midspan and also used dial gauges to get the deflections of the beam under different loading conditions.
Along with the readings I've obtained from the strain gauge, I have also used the deflections to calculate the strain in two other ways. I've done this through the deflections (curvature) and the experimental stiffness. The strain for deflections and experimental stiffness are virtually alike (highest error is 10%) however, in comparison to the strain gauge readings, there is a greater error (highest error ir around 30%).
I ensured that I performed the experiment correctly and given my raw results, they do seem correct. So, I'm wondering why do the experimental and theoretical results vary so much?
uhm, I can't put my finger on it but have you calculated the strain in the same direction in which the strain gauge is oriented?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
