Calculating Trajectory of a Plane Flying at 100m/s
The discussion focuses on calculating the trajectory of a plane dropping a bomb at a speed of 100 m/s from a height of 18 m, with the objective of determining the number of bounces and horizontal distance required for the bomb to land without bouncing over. Participants suggest using energy conservation principles to derive the vertical velocity at impact and the subsequent height of each bounce, emphasizing that mass cancels out in potential and kinetic energy calculations. The coefficient of restitution is mentioned as a factor in determining the velocity after each bounce, which reduces by a factor of 0.696. There is a suggestion to utilize a spreadsheet for iterative calculations rather than deriving a single analytical equation. The conversation highlights the complexity of rearranging equations without knowing the height of subsequent bounces, indicating a collaborative effort to clarify the problem.
qubert
Question is:
plane flies at a speed of 100m/s at a height of 18m above water
plot the trajectory from release to first impact point, in intervals of 0.2m
managed this and have plotted the trajectory, with relevant velocities and resultant but the next part asks:
"At each bounce the vertical and horizontal velocity is reduced by a factor of 0.696, if the resultant speed has to be between 5 and 6m/s determine the number of bounces and horizontal distance the bomb requires without bouncing over."
how would one rearrange the equations finding the first trajectory without knowing the height the second bounce starts from?
i thought maybe by using a quadratic and pythagoras:
(100x0.696B)^2+(18.78x0.696B)^2=5.5^2 where b is the number of bounces, 100 and 18.78 are the horizontal and vertical velocities on the first drop
is this anywhere near correct?
thanks
Firstly just consider the vertical direction.
Assume all the potential energy turns into kinetic at the ground.
Calculate the potential energy at the start and the kinetic energy at impact to get the vertical velocity at impact
Then use the new velocity to get the kinetic energy that it starts back up with.
Use this to get the potential energy and so the height of the next bounce.
Once you have the height and so the time for each bounce you can also get the horizontal velocity for each bounce in the same way.
I woudl probably do this a line at a time eg on a spreadsheet rather than trying to write an analytical eqaution for the end result.
is it possible to work out the potential energy without the mass of the object? would there be another way to work out the height of the next bounce?
The mass is in the potential energy and the kinetic energy so it cancels out.
If the only change is in the velocity then you can only work it out with kinetic energy, of course you can write the an equation for the height of the next bounce but that is just using ke/pe anyway
so pe=176.4j before being dropped and ke=176.4j at impact, how would it be rearranged to find out the new velocity? (ive never used these formulae before so sorry if I am slow) is the co efficient of restitution used here at all? thanks
ke = 1/2 mv^2 so V = sqrt( 2 ke / m )
Then the V immediately after the bounce is 0.696V or you can use the equation to calcualte what the change in KE would be directly without workign out the speed.
sorry I am still not following, would i be able to send you the excel spreadsheet i have so far so you can take a look at what I've done? thanks
