Calculating Velocity: Force, Mass & Distance Relationship
The discussion centers on calculating the velocity of a 1kg mass influenced by a force inversely proportional to the square of the distance from a point. The force equation is given as f = 10000/(y^2), leading to the acceleration a = 10000/(y^2). To find the velocity as a function of time, it is suggested to first derive the velocity in terms of the distance y, as y changes as the body moves closer to the point. Utilizing energy conservation principles is recommended to simplify the calculations. The main goal is to establish a clear velocity equation for the body attracted to another point.
The Trice
I have a body of 1kg of mass being acted on by a force of magnitude equal (10000/(y^2))
[where y is the distance between the body and a certain point] and this force is in the direction pointing to the point
so depending on what mentioned above :-
what i know is : f = a = (1000 0/(y^2))
and that Dy/Dt = V (velocity)
What is needed is the function of the velocity in terms of time.
Thanks for reading.
As you have said a=10000/(y^2)
==>Dv/Dt=10000/(y^2)
if y is a fixed value and independent of time ,integrating with respect to t
v=10^5(t)
y^2
ofcourse y is not a constant value since the distance which is y decreases as the body moves towards the point
any help ??
is it this hard i just want to know the velocity equation between body attracted to a point or another body!
You probably need to find the velocity as a function of distance y first. Using energy conservation would help with that.
