Calculating Visible Light Photons Emitted Per Second & Distance
The discussion focuses on calculating the number of visible-light photons emitted per second by a 200 W light bulb, which emits 10% of its power as visible light. The calculation yields approximately 6.03 x 1019 photons per second using the formula E = hf. The second part addresses determining the distance at which this corresponds to 1 x 1011 photons per square centimeter per second. The correct approach involves using the surface area of a sphere formula, A = 4πr2, rather than A = πr2.
  • Understanding of Planck's equation (E = hf)
  • Knowledge of power calculations in watts
  • Familiarity with the concept of photon flux
  • Basic geometry of spheres and surface area calculations
  • Learn about photon energy calculations using Planck's constant
  • Study the concept of photon flux and its applications in physics
  • Explore the geometry of spheres, specifically surface area calculations
  • Investigate the implications of light intensity and distance in photometry
Students and professionals in physics, particularly those studying optics and photometry, as well as educators looking for practical examples of light calculations.
EK86017
a.) If the average frequency emitted by a 200 W light bulb is 5x10^14, and 10.0% of the input power is emitted as visible light, approximately how many visible-light photons are emitted per second?
I solved this part of the problem by finding the energy (E = hf) and dividing 10% of 200W by the amount of energy per photon to get 6.03 x 10^19 photons per second.
b. At what distance would this correspond to 1x10^11 visible-light photons per square centimeter per second if the light is emitted uniformly in all directions?
I am stuck on this part of the problem. I tried dividing 6.03 x 10^19 by 1x10^11 to get the how many square centimeters would correspond to 1x10^11 photons per square centimeter per second. I got 6.04x10^8 cm^2. Because the light is emitted uniformly in all directions, I did A = pi*r^2, using the value 6.04x10^8 as "A". I got r = 138.7 m, but this is incorrect.
The problem I think I am having is A = pi*r^2 does not correspond to visible-light in the 3rd dimension, but I am confused as to why the question then does not ask "per CUBIC centimeter?"
Any suggestions would be very much appreciated.
Thanks!
Thanks!
Welcome to the PF. The surface area of a sphere is not PI * R^2...
http://www.teacherschoice.com.au/Maths_Library/Area and SA/area_2.htm
Thank you! It worked with 4pi*r^2
