Calculation Involving Thermodynamics, Gravitation and Fluid mechanics
The discussion revolves around a problem involving thermodynamics, gravitation, and fluid mechanics, specifically focusing on the behavior of a monoatomic ideal gas in a gravitational field and its relation to Stokes' law and diffusion.
  • Participants discuss the connection between diffusion, Stokes' law, and viscosity, with some expressing confusion about the relevance of these concepts in the context of the problem. There are attempts to understand the physical processes involved, including the behavior of gas molecules and the implications of viscosity on their motion.
The conversation is ongoing, with participants exploring different interpretations of the problem. Some have suggested looking into the Stokes-Einstein equation and the concepts of random walks and mean free paths as potential avenues for understanding the problem better.
Participants note that this problem is part of a competitive exam (JEE Advanced), which may influence the complexity and nature of the question. There is also mention of the need for a deeper understanding of the kinetic theory of gases and the dynamics of gas molecules.
Ayesha02
A monoatomic ideal gas is in gravitational field extended from the surface of the earth to a great height. Temperature of the gas is T and remains same at any height. At height 'h' number of molecules per unit volume 'n' is independent of time i.e equilibrium maintained. On the surface of the Earth n=##n_0##. Coefficient of viscosity of the gaseous medium is##N##. Stokes law is applicable. Radius of each spherical molecule is R. At height 'h' number of molecules diffusing upwards per unit area per second is given by -D dn/dh.
Find value of D. (boltzmann constant is K)
Stokes Law: F=6 pi ##N## r v
I figured out stokes law equation but I am unable to proceed further
Ayesha02 said:
Homework Statement:: A monoatomic ideal gas is in gravitational field extended from the surface of the Earth to a great height. Temperature of the gas is T and remains same at any height. At height 'h' number of molecules per unit volume 'n' is independent of time i.e equilibrium maintained. On the surface of the Earth n=##n_0##. Coefficient of viscosity of the gaseous medium is##N##. Stokes law is applicable. Radius of each spherical molecule is R. At height 'h' number of molecules diffusing upwards per unit area per second is given by -D dn/dh.
Relevant Equations:: Stokes Law: F=6 pi ##N## r v
I cannot understand what diffusion has to do with Stokes' law and viscosity. A trick question perhaps?
Probably. Its a competitive exam sum.
how to develop thought process in such sums?
It helps if you can think through the physical processes involved.
Gas molecules diffuse because they travel at great speeds, typically, and bounce elastically off each other. The energy involved is thermal, so there is no mechanical energy to be lost to heat.
Viscosity involves the loss of KE in a much larger body moving through a fluid.
Next step is to think why an upwardly moving gas molecule would not always shoot up to the highest point its KE could take it. But unless you have actually studied this topic it's a bit tough to figure it all out in an exam.
What exam is this?
Google diffusion, mean free path.
What exam is this?
Its JEE Advanced Exam- for entry into undergrad engineering.
and the molecule won't go upto the highest point as per KE because of viscosity isn't it? Viscosity'll retard it..
As I wrote, I would not say so. The kinetic theory of gases says they bounce off each other like perfectly elastic billiard balls.
Did you google diffusion and mean free path?
Try looking at the Stokes-Einstein equation
I still don't see the relevance. Those equations are for a relatively large particle moving through a fluid medium. Here we only have the molecules of the medium itself. Gaseous diffusion is governed by molecular velocity and mean free path.
Welp yes you’re right! Didn’t read it carefully enough.
Random walks and mean free paths are the way to go here.
  • · Replies 29 ·
