Calculus of Var, Euclidean geodesic
cpsinkule
Calculate the geodesic for euclidean polar coordinates given ds^{2}=dr^{2}+r^{2}dθ^{2}
standard euler-lagrange equation
I was able to reduce the euler-lagrange equation to \frac{d^{2}r}{dθ^{2}}-rλ=0 where λ=\sqrt{(\frac{dr}{dθ})^{2}+r^{2}} is the Lagrangian itself (namely the linear element)
My main concern is that I have the correct differential equation, I'm curious because I can't possibly imagine how this author expects me to solve that if it is indeed the correct DE for the lagrangian.
Were you asked to solve it? Most geodesic equations cannot be solved analytically and require numerical analysis.
I would think it would be easy to solve because it is obviously a straight line, that's why I think I have done something wrong to get this non-linear second order DE.
I do not necessarily think it would be easy. Given an arbitrary straight line that does not cross through the origin, how would you write this in polar coordinates? It is actually a very difficult thing to do.
so does that mean I have the correct DE? I'm not too worried about actually solving it, just that I have the right one and applied the E-L equations correctly to this problem
I haven't had to do this stuff in a long time, but I computed my geodesic equations to be
\frac{d^2 r}{dt^2} - r \left( \frac{d\theta}{dt}\right)^2 = 0, \qquad r^2 \frac{d^2 \theta}{dt^2} + 2r \frac{dr}{dt} \frac{d\theta}{dt} = 0
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
