Calorimeter Problem: Final Temp of Water & Ice Mixture
  • Thread starter Thread starter kill00
    Calorimeter
A calorimeter problem involves a 200 g aluminum calorimeter containing 300 g of water at 75°C, into which 20 g of ice at 0°C is added. The heat lost by the water as it cools to 0°C is calculated to be 94,185 J, while the heat required to melt the ice is 6,700 J. After accounting for the heat exchange, the final temperature is estimated to be around 66.5°C. The calculations also incorporate the heat absorbed by the aluminum, leading to a refined final temperature of approximately 66.6°C. The problem emphasizes the importance of considering all components in thermal equilibrium calculations.
kill00
A 200.0 g aluminum calorimeter holds 300g of water at 75 C. 20 g of ice at 0 C are added to the water. What is the final temperature of the mixture?
Use Lf= 33.5 x 104
Cal= 900 J/kg C
The answer is 66.5 C
Don't know where to start.
Well, this is what i came to:
Find the heat lost by the water, if it is cooled to 0 C:
(.3)(4186)(75) = 94185
Calculate the heat needed to melt the ice:
(.02)(33.5e4) = 6700Q left:
( 94185 - 6700) = 87485
Final temp = 87485 / ( .32)(4186) = 65.3 C
The answer is 66.5 C. I don't know what to do with the aluminum
Woohoo I think I got it:
QAL = (.2)(900)(65.3-75) = 1746
Final temp = (1746 + 87485) / (.32*4186) = 66.6 C
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
