Can a Tower of Books Move with Lighter Forces?
  • Context: Undergrad
  • Thread starter Thread starter Clockclocle
    Books Forces Tower
The discussion revolves around the mechanics of a stack of books and the forces required to move them. Participants explore the implications of applying forces to different books in the stack and the resulting frictional effects. The conversation touches on theoretical considerations, idealizations of the books' properties, and the practical aspects of force application.
  • One participant suggests that if a stack of n books is treated as a single particle, the force exerted by the last book (interpreted as the bottom book) is N=nmg, leading to questions about moving the entire tower with lighter forces.
  • Another participant clarifies that the last book does not contact the surface but exerts a friction force only on the book it is on top of, prompting confusion about the terminology used.
  • There is a discussion about the interpretation of "last book," with one participant suggesting it refers to the bottom book, while another argues it could mean the top book.
  • A participant introduces the idea that the answer depends on the idealization of the books, noting that if books are considered non-compressible and much wider than they are tall, the same motion could be achieved with different force applications.
  • Concerns are raised about the real-world behavior of books, emphasizing that the point of force application affects weight distribution and sliding ease, particularly when pushing below the center of mass.
  • One participant expresses confusion about the original question and suggests clarifying the terminology used to avoid misunderstandings, proposing the use of "top book" and "bottom book" instead.
Participants do not reach a consensus on the terminology used or the implications of the forces applied to the books. Multiple interpretations of the question and differing views on the mechanics involved remain unresolved.
Participants discuss idealizations such as treating books as identical, incompressible blocks with a specific friction coefficient. The implications of these assumptions on the mechanics of the stack are not fully resolved.
Clockclocle
Suppose n book stack on each other. Since each book have the same weigh then the last book exert a force N=nmg on the surface so it has the biggest static friction. But if we treat the whole tower of books as one particle it also has N=nmg. This mean if we exert enough force in the last book, the tower keep moving as we exert lighter force on all the book at the same time?
The last book does not make contact with the surface. It exerts a friction force only on the book it's on top of.
What? I think the last book would both contact with the surface and the top of it?
I think the OP is using "last book" to mean the one at the bottom of the stack. (I would call the top one the last book, since it was the last one placed on the stack, but the question makes more sense if it means the bottom book.)
In that case, the answer to the question depends on what idealisation you make. If you idealise the books as non-compressible and much wider than the stack is tall so there's no significant difference in torque between the two cases, then yes you can get the same motion by applying ##n## forces of magnitude ##F## or one of magnitude ##nF##.
In reality, books are typically slightly compressible and a stack of books will frequently be taller than it is wide. In that case where you apply the force matters because it will change how the weight is distributed which may affect how easily it slides. It's a fairly common experience that pushing something at a point below its center of mass is easier than pushing it at the top.
This is not possible: you can place a book on top of another book, but then the lower book is not on top of the top one. language .. :rolleyes:
It seems we mean different things when we mention 'the last book'. language ... :rolleyes:
Easier to only use 'top book' and 'bottom book'. Even better to make a sketch to clarify.
Could you now clarify your question ? I have difficuty understanding the last part...
(and let's assume the books all behave as identical ideal incompressible blocks, with a friction coefficient ##\mu## -- both between books and between bottom book and table. OK?)
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 18 ·
