Can any DC 12v or 24v motor be put on a speed control?
The discussion revolves around the feasibility of using speed controllers for 12v or 24v DC motors, specifically in the context of reducing the speed of a 24v DC bilge blower. Participants explore various methods and considerations related to motor control without causing damage or inefficiency.
  • One participant inquires whether any 12v or 24v DC motor can be used with a speed controller without risking damage or reduced performance.
  • Another suggests using a pulse width modulation (PWM) setup for speed control, based on personal experience with smaller motors.
  • A participant asks for recommendations on where to find a suitable pulse controller, indicating a lack of familiarity with the technology.
  • It is mentioned that special triac speed control units exist for AC/DC brush motors, and alternatives like linear adjustable voltage regulators or adjustable DC-DC converters could be used for DC motors.
  • One contributor shares their experience with programming a microcontroller to create a PWM signal for motor control, emphasizing the need for isolation circuits to protect against electromagnetic interference from DC motors.
Participants express varying levels of familiarity with speed control methods and components, indicating a lack of consensus on the best approach or specific products to use. Multiple competing views on the methods and technologies for speed control remain present.
Participants mention the importance of understanding power and current specifications, as well as the potential for electromagnetic interference when using DIY solutions. Specific details regarding the required specifications for controllers are not fully resolved.
This discussion may be of interest to individuals looking to control the speed of DC motors, particularly those involved in DIY electronics or motor control projects.
JeffJohnson1
I have an operation where I need to reduce the speed of a 24v DC bilge blower. My question is: Can I put any 12volt or 24volt DC motor on a speed controller and reduce the speed of the blower/motor without damaging the motor, creating an unsafe/over-heating condition, or without reducing the power/efficiency/performance of the motor? Thanks,JJ
you might try a pulse width modulation set up, depending on what your using as a controller for the motor, I've done this before but only on small scale. hope this helps.
thoughtprocess,
Any idea where I can get a pulse controller like this? Any help you can offer is greatly appreciated. I am a real newbie at this.
JJ
There are special triac (motor-rated) speed control units for 120 V ac/dc (brush) motors. You could put this upstream of a voltage reducing transformer. For reducing DC you could use a linear adjustable voltage regulator or a more efficient adjustable DC - DC (PWM) converter. What kind of power and current are you talking about?
I don't know of any place you can acquire the controllers because when i did it i used a 68hc12 microcontroller that i programmed myself to create the pulse width modulated signal depending on how fast i wanted the motor to run. you might try looking online at controllers that you can program yourself then try and find some idea as to the code that's needs to be written. And i guess the other thing is what is the currents you are working with.
you must realize that if you decide to try and program a controller yourself that isolation circuits will be need as dc motors can create emf spikes that will fry your controller.
