Can anyone explain the Grashof Criterion ?
  • Thread starter Thread starter M110020
    Explain
The Grashof Criterion determines the conditions for continuous relative motion in a planar four-bar linkage. It states that the sum of the lengths of the shortest and longest links must not exceed the sum of the lengths of the other two links. This relationship ensures that the mechanism can achieve full rotation without locking up. The criterion is derived from the geometric properties of linkages, and various mathematical proofs exist to validate it. Understanding this concept is crucial for analyzing and designing mechanical systems involving four-bar linkages.
M110020
Hi, I'm a university second year Mechanical Engineering student and I'm new to this module of Kinematics and Dynamics of Machinery and I've just learned the concept of the Grashof Criterion where "The sum of the shortest and longest link of a planar four-bar linkage cannot be greater than the sum of remaining two links if there is to be continuous relative motion between the links."
L_{max}+L_{min}\leqL_{a}+L_{b}
Can anyone explain to me why is it so? Why must the sum of the max and min linkages be longer than the other 2?? Is there a mathematical equation to prove this? Thanks for the assistance :)
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
