Can Hydraulic Circuits Transport Energy Without Compressible Oil?
Energy in hydraulic circuits is transported through the work done by incompressible oil rather than through changes in potential energy. Although oil is nearly incompressible, it can still experience pressure changes without altering its density. The internal energy changes of liquids due to pressure increases are minimal and do not contribute significantly to energy transport. Energy is effectively transferred from the source, such as a motor, to the load only when there is movement at the contact surface. Therefore, movement is essential for energy transport in hydraulic systems.
Jakob Weg
How can energy be transported in a hydraulic circuit? The volume of oil is nearly incompressible. Therefor energy can not be transported in the form of potential (inner) energy of the oil.
PΔV.
Incompressible doesn't mean that there can't be any change in pressure, it just means that the density doesn't change.
Internal energy change of liquids after pressure is increased is negligible. The energy from the source (motor) is transported to the load by work of the liquid in contact with the load when the surface of contact moves. If it does not move, there is no transport of energy.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
