Can I Find the Height of My Chimney Without Using Expensive Equipment?
  • Thread starter Thread starter Bernie Hunt
    Real world Trig
To determine the height of a chimney without expensive equipment, one can use trigonometry by measuring a distance from the base and calculating the height using the tangent of the angle to the top. A simple clinometer can be constructed to find this angle, allowing for a practical solution. Concerns were raised about the structural integrity of chimneys for mounting antennas, as they can deteriorate over time, potentially leading to accidents. It is advised to consider alternative mounting options, like a roof mount, especially if planning to extend the height significantly. Accurate height measurement is crucial for compliance with local regulations regarding antenna installations.
Bernie Hunt
This may be off topic, but a lot of smart and practical people hang out here so maybe someone can help.
I need to find the height of my chimny in my back yard. I'm not wild about heights, so I'd rather not get out a long tape measure and a longer ladder to climb to the top.
All the word problems we did in high school trig gave us all the pieces. Let's say I find a point 20 feet from the base, the 20*tan(x) where x is the angle to the top, is the answer.
How can I find the angle x, without purchasing some expensive surveying equipment?
Is there a better way to find the height?
The application is how height of an antenna I can attach to my chimney. The town says 40', so I need to know how high it is now, so I know how much mast to purchase. Also, when the inspector shows up, I need to prove that is isn't over 40 feet.
Thanks,
Bernie
Excellent idea. I used a framing square from the shop and got 23.25 feet.
Thanks!
Bernie
I'm a little leery of attaching antennas to chimneys.
Chimneys deteriorate after a while.
In any event, I had a rather expensive antenna AND the top of the double flue chimney hit the pavement after 5 years or so.
The chimney itself was more like 25-30 years and looked fine when I put it up, but if you have any cracks in the top cap they go quickly after that.
The mast on this was only about 4 or 5 feet, with the big antenna around 18" with a small one at the top.
If you are going to 40' then you need to guy the mast, which means the chimney needs to be centrally located.
Personally, I'd forget the chimney and go with a roof mount.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
