Can I Find the Height of My Chimney Without Using Expensive Equipment?
  • Thread starter Thread starter Bernie Hunt
    Real world Trig
To determine the height of a chimney without expensive equipment, one can use trigonometry by measuring a distance from the base and calculating the height using the tangent of the angle to the top. A simple clinometer can be constructed to find this angle, allowing for a practical solution. Concerns were raised about the structural integrity of chimneys for mounting antennas, as they can deteriorate over time, potentially leading to accidents. It is advised to consider alternative mounting options, like a roof mount, especially if planning to extend the height significantly. Accurate height measurement is crucial for compliance with local regulations regarding antenna installations.
Bernie Hunt
This may be off topic, but a lot of smart and practical people hang out here so maybe someone can help.
I need to find the height of my chimny in my back yard. I'm not wild about heights, so I'd rather not get out a long tape measure and a longer ladder to climb to the top.
All the word problems we did in high school trig gave us all the pieces. Let's say I find a point 20 feet from the base, the 20*tan(x) where x is the angle to the top, is the answer.
How can I find the angle x, without purchasing some expensive surveying equipment?
Is there a better way to find the height?
The application is how height of an antenna I can attach to my chimney. The town says 40', so I need to know how high it is now, so I know how much mast to purchase. Also, when the inspector shows up, I need to prove that is isn't over 40 feet.
Thanks,
Bernie
Excellent idea. I used a framing square from the shop and got 23.25 feet.
Thanks!
Bernie
I'm a little leery of attaching antennas to chimneys.
Chimneys deteriorate after a while.
In any event, I had a rather expensive antenna AND the top of the double flue chimney hit the pavement after 5 years or so.
The chimney itself was more like 25-30 years and looked fine when I put it up, but if you have any cracks in the top cap they go quickly after that.
The mast on this was only about 4 or 5 feet, with the big antenna around 18" with a small one at the top.
If you are going to 40' then you need to guy the mast, which means the chimney needs to be centrally located.
Personally, I'd forget the chimney and go with a roof mount.
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
