Can I Use the Same Car Charger for Both Laptops?
  • Thread starter Thread starter iancoric
    Car Charger
Using the same car charger for both laptops is acceptable as long as the charger provides at least the same voltage and current output as the manufacturer's charger. The charger in question outputs 18.5V and 4.9 amps, while the original charger provides 18.5V and 2.5 amps. Since the new charger can deliver more current than needed, it will work safely with the second laptop. The key factor is ensuring the voltage matches and the current capacity is sufficient. Overall, this approach should not pose any issues for charging the second laptop.
iancoric
I have two laptop computers but a car charger for only one of them. The charger says it produces 18.5V 4.9amps. Will this be OK for the other laptop - the specific charger sold by the manufacturer produces 18.5V 2.5amps. Thanks!
The current specifications on devices like these are the MAXIMUM current the device is able to supply. These devices produce a specific potential (voltage) and the thing you plug into it determines how much current must be delivered.
As long as your new charger can produce as least as much current as your old charger, you should be fine.
- Warren
Thanks - i was hoping you'd say that!
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
