Can someone check this limit please
  • Thread starter Thread starter mtayab1994
    Limit
mtayab1994
find the limit of:
\lim_{x\rightarrow0}\frac{1-cos(2x)}{tan(x)}
\lim_{x\rightarrow0}\frac{1-cos(2x)}{tan(x)}=\frac{1-1-\frac{x^{2}}{2}}{tan(x)}=0
if you're talking about using taylor expansions, then you should do the same thing for tan(x) to show its behaviour in the limit, and your expnasion is not correct due to the 2 in cos(2x)
however as this is 0/0 indeterminate I think you should use L'Hopital (which is in essence a similar thing)
you are doing right
mtayab1994 said:
find the limit of:
That should be
\displaystyle \frac{1-\cos(2x)}{\tan(x)}=\frac{1-\left(1-\frac{(2x)^{2}}{2}+\dots\right)}{\tan(x)}=\frac{1-1+\frac{(2x)^{2}}{2}-\dots}{\tan(x)}​
You can do this without using L'Hôpital's rule or Taylor series.
Start with cos(2x) = 1 - 2sin2(x) and 1/tan(x) = cos(x)/sin(x) .
mtayab1994 said:
find the limit of:
The lim symbol should remain until you actually take the limit. In the expression in the middle, above, the denominator is 0, so you can't conclude that the limit is zero.
kushan said:
you are doing right
See above.
SammyS said:
That should be
This is definitely the way to go.
after doing that i got:
\lim_{x\rightarrow0}\frac{-sin^{2}(x)*cos(x)}{sin(x)}=-sin(x)*cos(x)=-sin(0)*cos(0)=0*1=0
Is that correct?
Is that correct?
No. How did you get from (1 - cos(2x))/tan(x) to (-sin2(x)cos(x))/sin(x)? Show us what you did to get that.
Also, the lim symbol needs to appear until you actually take the limit. In other words, as long as x is still in any expression, you haven't takent the limit.
Well, i replaces 1-cos(2x) with 1-1-sin^2(x) and the bottom from tan(x) to sin(x)/cos(x)
Then i removed the denominator by 1/tan(x).
You have two mistakes. That should be 1 - (1 - 2sin2(x)).
alright and for the denominator should i do tanx=sinx/cosx?
Ok i got (2sin^2(x)*cos(x))/(sin(x))
then i canceled out with the sine and i was left with 2sinx*cosx which then equals 0 is that correct?
Yes.
2sin(x)cos(x) doesn't equal 0, but the limit as x approaches 0 of this expression is 0.
In other words,
2sin(x)cos(x) ≠ 0, but \lim_{x \to 0} 2sin(x)cos(x) = 0. There's a difference here.
Mark44 said:
Yes.
In other words,
Yea sorry i didn't write, that but is what i did correct?
mtayab1994 said:
Yea sorry i didn't right that but is what i did correct?
The value of the limit is 0, but what you wrote is not correct.
Again, 2sinx * cosx ≠ 0, in general.
I don't get it what's wrong with that. Isn't the limit as x approaches 0 of 2sinx*cosx=0?
Yes, but what you said didn't include the word "limit," so isn't true.
True:
\lim_{x \to 0}~2sin(x)cos(x) = 0
False:
2sin(x)cos(x) = 0
I'm am trying to get you to distinguish between the value of an expression and the value of the limit[/color] of that expression.
Do you see the difference now?
True:
False:
2sin(x)cos(x) = 0
Yes thank you I appreciate it :smile:.
