Can the velocity in a funnel be higher than in freestream?
  • Thread starter Thread starter John Mcrain
    Velocity
The discussion centers around whether the airflow speed in a funnel can exceed the freestream speed when the funnel is placed outside a moving car. It is suggested that while Bernoulli's principle indicates that airflow speed should increase in the funnel's narrow section, real-world factors like turbulence and drag complicate this application. Participants argue that the speed at the funnel's outlet will always be lower than the freestream speed due to energy conservation principles and pressure differentials. The conversation also touches on the impact of funnel design on airflow and the importance of considering multiple factors affecting mass flow. Ultimately, the consensus leans towards the conclusion that the airflow exiting the funnel cannot exceed the freestream speed.
John Mcrain
If I put funnel out of car when driving 100km/h, can speed in narrow section in funnel be higher than 100km/h(freestream) and does bernuli equation works for this case?
Have you tried to work on this at all on your own?
yes I know how to solve it using bernulli,total pressure must be same,but I don't know can I use it for this case..
Can anyone answer?
The speed of airflow within the narrow section should be higher than the speed of the freestream.
There should be a pressure differential between inlet and outlet cross-sections.
I believe that there is enough turbulence and drag around the funnel for the Bernoulli principle not to be fully applicable in this case.
Copied from
https://en.m.wikipedia.org/wiki/Bernoulli's_principle
"Bernoulli's equation is valid for ideal fluids: those that are incompressible, irrotational, inviscid, and subjected to conservative forces. It is sometimes valid for the flow of gases: provided that there is no transfer of kinetic or potential energy from the gas flow to the compression or expansion of the gas."
There will almost always be some inviscid core flow through such a funnel in which Bernoulli is perfectly applicable.
I was more interested in what thought process @John Mcrain had already gone through one way or the other here.
Likes hutchphd
thanks for answer
Suppose the funnel throat were totally closed (i.e., zero diameter exit opening). What do you think the streamlines would look like?
John Mcrain said:
thanks for answer
You are welcome. :smile:
Consider that more mass of air will be able to flow through the narrow section as the slope of the funnel is smaller (more gradual transition between wide and narrow sections).
Also, watch the attached video to see how much disturbance of air is created by the the car next to the funnel.
That disturbance greatly affects the the stability of the direction of the flow entering the funnel, as well as the static pressures upstream and downstream, all of which move the situation away from the conservation of energy involved in Bernoulli's equation.
Indy racing league race cars use underbody tunneling to speed up the free stream flow (relative to the car), to lower pressure for more downforce. Formula 1 race cars are required to use skid-plates for their underbody, but still benefit from air being sped up under the race car body. Both use rear end "diffusers" that provide a transition region behind the car for the lower pressure, faster moving air to increase pressure and slow down, which increases the underbody effects.
That's not at all a generally true statement.
Where is there any kind of funnel in that video?
To increase the velocity through the small end of the funnel the kinetic energy must be increased. To increase the kinetic energy the static pressure must be lowered as per the Bernoulli equation. The flow coming out of the funnel needs to have the same static pressure as the surroundings, flow upstream of the funnel exit can only have a higher static pressure.
This means there is a buildup of static pressure in front of the funnel lowering the kinetic energy of the flow before it enters the funnel. Only then it can increase its velocity again through the small part of the funnel. So when air approaches the funnel its kinetic energy will first be converted to static pressure and then to kinetic energy again. For a perfect conversion the kinetic energy will thus be at most what it began with, thus the velocity through the small end of the funnel can thus at most be equal to the surrounding velocity.
However, at the moment the pressure just before (or in the cone of) the funnel is increased, flow will seep (escape) alongside the funnel, meaning that not all of the kinetic energy that 'hits' the upstream end of the funnel can be used to increase the static pressure. Therefore you 'loose' pressure and the flow through the small end of the funnel is lower than the surrounding flow, always.
On top of this there are also losses due to turbulence and friction.
Likes 256bits and Lnewqban
How would you improve the statement, if at all possible?
Likes Greg Bernhardt
Well for one, I've been avoiding throwing out answers in this thread since @John Mcrain has not shown us any evidence of trying to figure this out on his own, but for starters, your statement pretends there is only one factor affecting mass flow through the funnel. In fact, there are many. The slope is only one possible factor.
The slope of the funnel, for example, can either increase or decrease the amount of mass that might reasonably flow through the funnel. A funnel with a better contour (which likely includes some length) will reduce the risk of boundary-layer separation, which would tend to reduce mass flow through the funnel. On the other hand, the longer you make it, the thicker the boundary layers get, so that will reduce the mass flow through the funnel.
Likes Lnewqban
If "funnel" looks like this,than constriction cause increase static pressure and lower speed then freestream?
I don't see how any of my arguments would be different for this case. Why do you think this makes a difference?
I just double check .So every constriction reduce speed compare to freestream..
My first funnel...
Isnt flow higher speed then freestream when leave funnel outlet,becuase air has mass, so it has inertia,so it keep going for short time?
Or flow decelerate inside funnel narrow section to match freestrem speed when leave outlet?
Air indeed has inertia, but to say that the speed at the outlet of the funnel is higher than free stream means that this inertia (or momentum actually, inertia times velocity) is increased, how would that work? What would be the energy source that does that? It is just not going to happen. Look at it this way:
Say you are standing on the side of the road and a car passes by from left to right. It is a day without any wind. The car drags air along with it and therefore, when the car has just passed, a part of the air will also go from left to right because it was dragged along with the car.
Now someone holds a funnel out of the window of the car the way you drew it. What you claim by saying that the outlet speed of this funnel is higher than the free stream velocity means that after the car has passed, some of the air will go from right to left! This is intuitively very strange isn't it? you move something through air from left to right, and afterwards the air is supposed to move from right to left... This is not possible.
It will not match the freestream velocity, it will always be slower. First because there is always some friction. Second because of a more theoretical argument that I made in my first post which doesn't need any friction or turbulence to work.
Correct. The only way to increase the speed is when you add energy to the flow, like with some kind of pump.
So basicly you answer is opposite from other members
Apparently, should I have conceded? ;)
I am really suprised that @boneh3ad has opposite answer from yours!
So bernulli will take me to wrong answer...
First: I don't see @boneh3ad making any statement about the exit velocity of the funnel being higher or lower than free stream in any of his posts here.
Second: Even if he did, so what?!? Are we going to vote now as to whether the outlet velocity is higher or lower than the surroundings? Do you think the air would care? What are you trying to say here? My arguments don't count because someone else who you apparently think high of doesn't agree? Shall we please keep it to actual arguments on physical processes please? This is a physics forum, not an opinion forum!
Third: Even if he was correct and I was wrong. What are you trying to say here? You are still to point out why he is correct! He is not correct because he's called boneh3ad!
Fourth: I also used Bernoulli (that's how you write it) in my argument...
Fifth: I have a lot of respect for @boneh3ad, he seems to know a lot about the topic and I agree with his remarks in this thread.
Leave now exit of outlet velocity,this was disccused between only you and me..
You said that velocity in narrow section in funnel will be allways slower then freestream.
bonh3ad wrote " There will almost always be some inviscid core flow through such a funnel in which Bernoulli is perfectly applicable" as respons to Lnewquban post. So he implies that using Bernulli I will get answer...
Lnewquban wrote that speed will be higher then freestream(opposite from yours),bonh3ad didnt complain nothing about it,he just add it that I can use bernulli for core flow..
I am suprised becuase I think he is proffesor of fluid dynamics
I did and I stand by that.
I agree with what boneh3ad said here, in fact, as I mentioned, in my first argument I also used Bernoulli. But it has no implication to whether the exiting flow speed will be higher or not than the surroundings.
True, but he also liked my post on why I think that is not true.
He also didn't complain about my post. Not posting anything tells you exactly nothing about what his viewpoint is on the topic.
Maybe he is, maybe he knows more about fluid dynamics than I do, but what does that mean? Status doesn't count, only arguments do. (status does make me take his arguments more serious though :) )
Alright, enough of this nonsense... This was my last post in this thread. There is already more than enough nonsense going on in the world this day... 😢
Look I am here to learn,not to teach.
How do you expect me to know which answer is correct,if members have opposite answers?
If you know that you are 100% correct,then you first sentences must be: "Why you write man wrong answers?" or "shame on you,you are giving man wrong answers..etc
wing has higher speed on upper surface then freestream, without pump.
Similarly, the flow outside your funnel might be faster than freestream. But that doesn't imply, that the flow somewhere in the funnel will be faster than freestream.
First, if fluid is incompressible and the flow is steady and moving into the funnel at a rate of ##\dot{m}##, it is therefore also leaving the funnel at a rate of ##\dot{m}##. Obviously the exit velocity has to be faster than the inlet velocity. It would break conservation of mass otherwise.
Second, one of the issues that people seem to have here is that the flow through the funnel does not occur independently of the flow outside the funnel. The funnel presents some resistance to flow that doesn't exist in the free stream. This makes it very difficult to generalize anything. If the opening is small, consider that it will behave in some ways like a Pitot probe where the flow in the front slows down (though doesn't entirely stagnate). If the opening is very large, this effect would only be large near the edges.
Also consider that the flow outside the funnel would be important. The outer shape of the funnel is important in determining what the wake of the funnel looks like into which the flow through the center would be discharged. The external flow will accelerate around the funnel and the pressure will drop, so the pressure into which the funnel discharges is not the same as that of the free stream.
But all of this is heavily dependent on both the internal and external shapes of the funnel. Incompressible fluids are governed by elliptical equations. What happens in one location affects every other location simultaneously (obviously an approximation to what we observe in real life, where nothing is actually perfectly incompressible).
Likes hutchphd and Lnewqban
Maybe the more general question would be:
Is it at all possible to increase the flow speed through some kind of "funnel" beyond the free-stream speed?
Shrouded turbine designs have the funnel placed the other way around, compared to what the OP suggests, with the rear getting wider.
  • #31
With the initial configuration, I would say no.
With another configuration, yes .
Likes A.T.
  • #32
Increasing the flow speed to beyond the free stream velocity with an object of any shape without it adding energy to the flow, disregarding local flow accelerations (i.e. behind the object), is a perpetuum mobile...
  • #33
So it seems that speed in narrow section in funnel will be faster then freestream,because of pressure drop in wake?
  • #34
I think perpetuum mobile is if we increase total pressure of flow,without adding energy.
But playing with speed(kinetic energy) and static pressure is possible if their sum not exceed total pressure of freestream.
Isnt it?
  • #35
Downstream of this object, the pressure is necessarily equal to the surrounding pressure. If the velocity is then higher than the free stream velocity, the total pressure has indeed increased.
Likes 256bits
  • #36
Yes but topic-question was ,is speed in narrow part of funnel higher than freestream,not downstream of object..
  • #37
If it is higher in the narrow part of the funnel, it is also higher downstream of it, due to inertia.
  • #38
Yes I noticed that " inertia-paradox" in some of my posts..
But if outlet of funnel is in wake,than we get favorable pressure gradient to accelerate flow inside narrow section..
  • #39
Ok, put a surface at the inlet of the funnel (the thick part). Measure the average velocity on that surface, also measure the massflow through that surface. Now do the same measurement at the outlet of the funnel. Necessarily, as per the continuum equation, the massflow at both surfaces need to be equal and the average velocity at the outlet surface of the funnel is higher than at the inlet surface, so there is indeed an acceleration of the flow inside the funnel.
However, the maximum velocity leaving the funnel is necessarily lower than free stream as per my earlier arguments. This means that the average flow velocity is definitely lower than free stream. This means that at the inlet the flow is blocked. So the flow is already lowering its velocity before it enters the funnel...
  • #40
These surfaces I mentioned are virtual by the way, they do not affect the flow.
And just to be clear, the average velocity on the inlet surface is way lower than free stream (it seems you might be thinking it is equal to free stream). It is in fact so low, that even after acceleration through the funnel, the exit velocity of the narrow part is still lower than free stream.
  • #41
If you work with CFD you can't post some pictures of this,if it is not complicated so much to do..
I have pitot tube and one big funnel so I can try this with car test..
  • #42
But question is about local flow speed, not about a net increase overall.
  • #43
If you want to increase the net flow overall, you at least need to increase the local flow speed right...?
  • #44
Arjan82 said:
If you want to increase the net flow overall, ...
I don't. The question is only about the local flow through some kind of funnel, compared to freestream.
  • #45
Oh, wait... your argument was the other way around 😁
So, all streamlines entering the funnel come from an equal source, i.e. the total pressure (or the Bernoulli constant) on any streamline entering the funnel is equal. Since increasing total pressure means adding energy, nowhere, on any streamline does the total pressure increase. So when the static pressure has recovered to the free stream value just behind the funnel, and since the sum of static and dynamic pressure (i.e. kinetic energy) is the total pressure, the kinetic energy on any of the streamlines can be at most what it was before entering the funnel, i.e. it can at most be the free stream value.
The flow inside the narrow part of the funnel continues downstream of the funnel if there are no losses. This is because the geometry of the narrow part of the funnel nor the open space behind it will decelerate the flow (it doesn't constrict the flow in any way).
  • #46
I might have a look this evening. We indeed have a bit of code that can do this quickly. It will not be an exact funnel shape, more actually like the second configuration you showed.
  • #47
  • #49
Yes, and "a handheld anemometer was positioned at various locations in the flow field to gain some understanding of the velocity field near the rotor" So these are local flow velocities.
I explicitly excluded local flow accelerations, which can indeed be higher than free stream (in which case the pressure is lower than static free stream pressure, to keep total pressure in check). But also in the paper the average flow velocity, averaged over the entire inlet, cannot be higher than free stream.
Personally, I think this paper is bullocks... They claim significantly higher than Betz efficiency (2.65 times more!) which is highly controversial. With a duct it might be possible to increase the effective diameter of the rotor a bit, such that in theory you could exceed Betz if you base it on the rotor diameter (instead of the total diameter of rotor + duct). In practice you would likely still be below Betz because most turbine don't exceed Cp = 0.5. But in no way can this lead to a factor of 2.65. This thing is also a far cry from the funnel, without a any turbine in it, of the OP.
So, can you have a local acceleration of the flow at certain parts inside a duct exceeding free stream? Sure, that kind of diverging shape this might be possible.
But the OP actually showed a funnel. A funnel has a narrow part which has either constant cross section or is contracting even further. In that case there will also not be local flow inside the funnel with a velocity higher than free stream.
I also implicitly assumed the simple case of a narrow part with constant cross sectional area. If there are no losses, then the flow inside this narrow part, once established, continues forever, also downstream of the funnel. This means that if the local flow velocity inside the narrow part exceeds free stream, it will also do so downstream of the funnel.
Lastly, you are now talking about very local effects. Nowhere in the OP or in any subsequent posts of him did I understand that he would like to know about these kind of effects (which depend on many things, for which indeed no general statement can be made). I have interpret them as at the very least averaged over the entire cross section.
  • #50
Lets say you vary the diameter of the opening in the duct shown below. Can the flow speed, averaged over an entire cross section of the opening, ever be greater than freestream speed?
