Can Two Bodies Achieve Thermal Equilibrium Without Contact?
  • Thread starter Thread starter beterban
The discussion revolves around the concept of thermal equilibrium and related thermodynamic processes, including the behavior of gases, heat transfer, and the properties of materials in thermal contexts.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster poses multiple questions regarding thermal equilibrium, gas expansion under different conditions, and the efficiency of wrapping food for cooking. Some participants suggest considering the nature of heat transfer and the properties of materials involved.
Participants are engaging with the questions by offering hints and prompting further thought rather than providing direct answers. There is a mix of interpretations regarding the questions, particularly about the thermal properties of materials and the conditions for thermal equilibrium.
The original poster expresses some uncertainty about the questions and the level of knowledge expected in the forum, indicating a potential gap in understanding the underlying concepts.
beterban
HI,
I have some question i hope i can fine the answer here:
1) is it possible for two bodies to be in thermal equilibrium without being in physical contact?explain
2)an ideal gas expands to twice its volume under isothermal and adiabatic conditions. in which case is the final temperature the highest? in which case is the change in internal energy greatest?
3)an aluminium foil has one shiny surface and one dull surface. how would you wrap the potato to bake it efficiently? explain
4)how much heat is needed to convert 80g of ice initially at-10 C to 60g of water and 20g of steam at 100 C?
specific heat capacity of ice=2100 JKg-1K-1, specific heat capacity of water= 4190 JKg-1K-1, latent heat of fusion of ice=334 kJkg-1, latent heat of vapourisation of water=2260 kJkg-1
thanx in advance
Welcome to PF beterban.
I'm not going to give you the answers, but make you think yourself :-p
But here are some hints:
In 1): Suppose two bodies are not in equilibrium. What would have to be transferred to establish equilibrium? Is it something for which physical contact is needed or not?
For 2) you can use the ideal gas law. Can you quote it?
Your intuition may even help you in 3): one of the sides will reflect the heat, the other will absorb it... which side is which do you think?
For 4) you will need to do something with the heat capacity. What is the heat capacity and how can you use it?
For what it's worth, #3 is one of the great folk myths. For ordinary aluminum foil, it makes no discernible difference. If the aluminum foil is the non-stick kind, shiny side goes out.
http://www.alcoa.com/reynoldskitchens/en/faq_detail.asp?info_page_id=743&prod_id=1789&cat_id=1337
:rolleyes: you know..!
When i think about it i will find that it is possible if the mass,material (specific heat) & surrounding temperature not be in thermal equilibrium
am I correct?
sorry but why you don't ?
and thanks to TVP45 for the information which he has been provided
I think there aren't enough knowledge in this forum,those is easy question but I'm not sure from some and didn't understand the other some what sould i do than?
I hope this useful to get help
beterban
