Can we achieve linearity in helical springs like in cantilever design?
  • Thread starter Thread starter thadman
    Linearity Springs
The discussion revolves around the potential for achieving linearity in helical springs, comparing their behavior to that of cantilevers. Participants explore the design, characteristics, and applications of helical springs, including their linear behavior under load and the implications of different spring geometries.
  • Some participants assert that typical, cylindrical, uniform, helical springs exhibit approximately linear behavior similar to cantilevers, provided the coils have not closed.
  • There is a question regarding the linearity of the spring force across the contact surface, with one participant suggesting that the shape of the contact force curve may vary based on the spring end treatment.
  • One participant expresses uncertainty about the existence of multiple arm, helical compression springs and questions whether a compression spring can operate in both compression and expansion.
  • Another participant suggests that a single wire is commonly used in helical springs due to manufacturing ease and potential benefits over multiple wires.
  • There is a discussion about the feasibility and advantages of using two identical springs oriented 180 degrees apart, which could reduce stress compared to a single spring.
  • Participants discuss the complexity and cost implications of designing springs that can handle both tension and compression.
  • One participant presents equations related to the natural frequencies of cantilevers and inquires about defining similar equations for helical springs.
  • Another participant provides equations for defining natural frequencies of beams and seeks clarification on the second moment of inertia for helical springs.
Participants generally agree that helical springs can exhibit linear behavior similar to cantilevers under certain conditions. However, there are multiple competing views regarding the design and functionality of helical springs, particularly concerning the existence and practicality of multiple arm designs and the operational capabilities of compression springs.
Participants express uncertainty about the specific characteristics of contact force curves and the implications of different spring geometries. There are also unresolved questions regarding the mathematical modeling of helical springs and the definitions of relevant physical parameters.
thadman
For the design of a cantilever, assuming a Hookean material is used below its proportionality limit, stress will be proportional to strain. From this we can conclude that its behavior will be linear.
However, how can we apply this knowledge towards helical springs? Is it possible to design a helical spring whose linearity approaches or equals the cantilever?
Thanks,
Thadman
Yes, typical, cylindrical, uniform, helical springs, whose coils have not started to close, have approximately linear behavior, like the cantilever.
nvn said:
Yes, typical, cylindrical, uniform, helical springs, whose coils have not closed, have approximately linear behavior, like the cantilever.
Assuming a cylindrical, uniform, helical spring, whose coils have not started to close, which supports a surface. Would the spring force be linear across the contact surface?
I don't know the shape of the contact force curve on the contact surface. I think the shape of the contact force curve would probably tend to vary depending on the spring end treatment (wire shape and pitch).
yes springs are linear and full contact as the top and bottom is " flat " or they can be made without the " flat" ends
see link below for more infohttp://www.hypercoils.com/
After some brief research, I see that a variety of helical spring topologies are utilized in designs. However, I'm still unable to find an example of a multiple arm, helical compression spring. All of the examples I'm aware of involve a single arm. Is there a reason for this?
Can the compression spring operate equally in compression as well as expansion?
Hi thadman,
What do you mean by a "multiple arm" spring? Are you referring to a type of disk spring?
http://www.mcmaster.com/#disc-springs/=3pweox
There are a lot of different types of springs, but the most common use a single wire wound into a helix. The spring constant remains constant over the usable range of the spring unless it's specifically made not to. In other words, helically wound springs produce a force that is very linear with respect to displacement. They are commonly used in both tension and compression.
I was wondering why a single wire is often used as compared to multiple wires.
Is the single wire simply easier to manufacture? Does it offer benefits compared to multiple wires?
Helical springs are often used in either compression or tension, why not both? If the spring was rigidly coupled to 2 parallel plates, couldn't it function both in tension as well as compression?
As far as visualizing a multiple arm helical spiral, imagine a multiple arm logarithmic spiral and the differences that exist between it and a logarithmic spiral.
(multiple arm) http://1.bp.blogspot.com/_SqhhJb_P3...I/TJksEbXxyo4/s400/blue,+green+spiral+top.gif
(single arm)
http://www.cs.princeton.edu/introcs/32class/images/logspiral.png
A multiple arm, helical spring would simply use multiple wires would into a helix
I've seen helical springs that are nested, one inside another (ie: one diameter is larger than the other) but I've not seen them made with two wires of the same diameter as you've suggested. I could be done, just take 2 identical springs and orient them 180 degrees apart. They couldn't be closed and ground for obvious reasons, but it would work if you had end plates made up to accommodate the end configuration.
Looks like there's an advantage to doing this actually. Comparing 2 springs with 1, both with the same total spring rate, the 2 springs will have less stress for any given load than the single spring.
The problem is it adds a lot of complexity and cost to a design.
Springs can be made to handle both tension and compression but that's generally not needed. If there were some design reason to produce a spring that works in both compression and tension, it wouldn't be a big deal to design it like that.
I picked up the seventh edition of Roark's formulas for Stress and Strain. It appears to be rather trivial to calculate the fundamental resonance for a helical spring. However, calculating the mass normalized modes does not appear to be trivial.
Assuming a cantilever (left end fixed, right end free), an equation exists which defines all of the natural frequencies.
F(x)=(K(n)/2pi)*sqrt(EIg/wl^4)
Where K(n) = 3.52 for the 1st mode (n=1), 22 for the second mode (n=2), 61.7 for the third mode (n=3), 121 for the fourth mode (n=4), 200 for the fifth mode (n=5), etc.
Nodal position wrt length = .783 for the 2nd mode (n=2), .504/.868 for the third mode (n=3), .358/.644/.905 for the fourth mode (n=4), .279/.5/.723/.926 for the fifth mode (n=5), etc
How can we define a similar equation for a helical spring?
With regards to my previous posts,
For defining the natural frequencies of a beam rigidly coupled at both ends, we are given the equation:
F(X)=(Kn/2pi)*sqrt(EI/Rho*A*(L^4))
where:
Kn=mode number
E=elastic modulus
I=area moment of inertia (ie second moment of inertia, I believe)
Rho=mass density
A=cross sectional area
L=length
However, what second moment of inertia equation do we want? I believe we can calculate it with respect to both X and Y, where (assuming a rectangular cross-section) I(x)=b(h^3)/12 and I(y)=h(b^3)/12 and h=height (ie y) and b=width (ie x).
  • · Replies 23 ·
