How can you integrate a vector without decomposing it in x and y components?
  • Thread starter Thread starter mad
    Integrate Vector
Integrating a vector without decomposing it into x and y components is possible by treating the unit vector as constant if its direction does not change over the integration range. In the discussed scenario, the electric field at x=0 can be calculated using the formula \(\vec{E} = \int \frac{k \lambda dx}{x^2} \vec{u}\), where \(\vec{u}\) is the direction of the electric field. The unit vector \(\vec{u}\) is directed negatively along the x-axis, simplifying the integration process. If the direction remains constant, the unit vector can be factored out of the integral, allowing for a scalar integral to be computed. This approach streamlines the calculation while maintaining vector integrity.
mad
Hello, I just wanted to know if you can integrate a vector, and if so, how.
Here is a problem: A charged piece of metal of linear density 2 * 10^-6 * x , between x=2 and x=5.
I found its charge by integrating.. and it is 21 micro C.
Now that's what I want to know: calculate the electric field at x=0
I know that \vec{E} = \int{} d \vec{E}
but in my physics book, it says I have to decompose it in E_x or {E_y} and integrate. But since I hate working without vectors, do you think there's a way to integrate without decomposing it in x and y, like something like this..:
\vec{E} = \int{} \frac{k dq }{r^2} \vec{u} = \vec{E} = \int{} \frac{k \lambda dx }{x^2} \vec{u}
Is there a way to do this? My teacher hasn't started this topic yet, I'm just curious.
Thanks a lot !
\vec{E} = \int{} \frac{k dq \vec{u}}{r^2} = \vec{E} = \int{} \frac{k \lambda dx \vec{u}}{x^2}
Thanks a lot !
What is the direction of the unit vector \vec{u} ?
Daniel.
Daniel.
It is -i , since they ask the electric field at x=0 . Is there a reason you are asking this?
Yes,i wanted to know whether it was constant or not.If it is,then u can take it outta the integral and compute the "scalar" integral (which yields the component of \vec{E} along the direction of \vec{u})...
Daniel.
Daniel.
k \lambda \vec{i} \int \frac{dx}{x^2}
You mean this? We have just started integrals in math., so I may have confused some things.
