Troubleshooting Ubuntu: How Do I Connect to WiFi on My Computer?
  • Thread starter member 428835
  • Tags
    Ubuntu Wifi
In summary, the conversation was about a computer experiencing wifi connection issues. The person tried restarting the machine and forgetting the network, but when trying to reconnect, a username and password were requested. The issue was eventually resolved by selecting "wifi settings", toggling the network, and selecting the "security" tab. The person noted that the "Tunneled TLS" setting worked for them after initially trying a different setting. The cause of the problem is unknown, but this solution worked for the person.
member 428835
Hi PF!
Today my computer randomly didn't connect to wifi. So I restarted the machine, then still unable to connect, I asked my wifi to forget the network. Now when I try connecting to it, it asks for a username and password. At the bottom there is a "connect" button I could toggle, but it is grayed out, I cannot click it. Any help is greatly appreciated!
Computer science news on Phys.org
I just fixed the issue. Evidently you need to select "wifi settings", toggle the network you want to connect to, and then select the "security" tab. For some reason "Tunneled TLS" works for me, though I should note initially it was this, so I toggled off to a different setting, tried connecting, then reselected Tunneled TLS. Unsure how long it'll work or why the problem came in the first place, but this worked for me.
Likes jedishrfu, Wrichik Basu and Bystander
Thanks for the update as many of us geeks use Ubuntu.
Likes member 428835
1. How can I troubleshoot my Ubuntu WIFI connection?
To troubleshoot your Ubuntu WIFI connection, you can try the following steps:
1. Check if your WIFI is turned on and that your device is connected to the correct network.
2. Make sure your router is functioning properly by checking other devices connected to the same network.
3. Restart your router and modem.
4. Check if your WIFI driver is up-to-date.
5. Try connecting to a different network.
6. Restart your device.
2. Why is my Ubuntu not showing any available WIFI networks?
There could be several reasons for this issue. Some common causes include:
1. Your WIFI is turned off.
2. The network you are trying to connect to is out of range.
3. Your network adapter is not supported by Ubuntu.
4. Your WIFI driver is not installed or outdated.
5. Your device's network settings are misconfigured.
To fix this problem, try turning on your WIFI, moving closer to the WIFI source, updating your WIFI driver, or resetting your network settings.
3. How do I connect to a hidden WIFI network on Ubuntu?
To connect to a hidden WIFI network on Ubuntu, follow these steps:
1. Open your system settings and go to Network.
2. Click on the "+" button to add a new WIFI network.
3. Enter the network name (SSID) and select "Hidden network" under the Security drop-down menu.
4. Enter the network's security key and click Connect.
Your device should now be connected to the hidden WIFI network.
4. Why does my Ubuntu keep disconnecting from WIFI?
There are a few possible reasons why your Ubuntu may keep disconnecting from WIFI:
1. Your device's WIFI adapter may be malfunctioning.
2. Your WIFI signal may be weak or unstable.
3. Your device's power management settings may be affecting the WIFI connection.
4. A software bug or compatibility issue may be causing the disconnection.
To fix this issue, try updating your WIFI driver, moving closer to the WIFI source, adjusting your power management settings, or troubleshooting for software issues.
5. How do I set up a static IP address for my Ubuntu WIFI connection?
To set up a static IP address for your Ubuntu WIFI connection, follow these steps:
2. Click on the gear icon next to your WIFI connection.
3. Under the IPv4 tab, select "Manual" from the Method drop-down menu.
4. Enter your desired IP address, netmask, gateway, and DNS server.
5. Click Apply and your WIFI connection will now use a static IP address.
Note: Make sure the IP address you choose is within the range of your network's IP addresses.
  • Computing and Technology
