Cannot solve Problems related to a Clock
The discussion focuses on solving problems related to the mechanics of a clock, specifically calculating the speed, velocity, and angles of the hour hand at 3 hours, 27 minutes, and 49 seconds. The hour hand measures 15.0 cm, and the calculations involve converting time into hours and determining the central angle, which is found to be 103.9 degrees. The user initially struggles with the geometry of the clock hands but is advised to apply the law of sines or the law of cosines to resolve the oblique triangle formed by the clock hands.
  • Understanding of angular motion and speed calculations
  • Knowledge of basic trigonometry, including the law of sines and law of cosines
  • Familiarity with the concept of displacement in physics
  • Ability to convert time units for calculations
  • Study the law of sines and law of cosines for solving oblique triangles
  • Learn about angular velocity and its applications in rotational motion
  • Research the relationship between linear speed and angular speed in circular motion
  • Explore advanced problems involving clock mechanics and angular displacement
Physics students, educators, and anyone interested in the mechanics of rotational motion and angular calculations related to clocks.
ConfusedPhysics
"A clock has an hour hand that is 15.0 cm long, a minute hand that is 20.0 cm long, a secondhand that is 25.0 cm long."
"The time is 3 h 27 min 49 s"
"the hands are moving clockwise"
"for the hour hand calculate
1. speed of the hand
2. velocity of the hand at the given time"
"presume the hand from the the 12 position and find the change in
3. velocity,
4. average velocity,
5. average acceleration,
6. displacement"
The thing i am having the most trouble with is finding the central angle for the clock.
if i change time time into hours, it equals to 3.46 hours
if I multiply it by 30 to find the angle since each hour is 30 degrees to 12 o'clock it equals to 103.9 degrees.
but if i create a triangle using that number and the radius of the hour hand it will look like
this.
but this triangle does not make any sense since if solve for any of the other angles it will equal to
x= tan-1 (15/15)
x=45 degree
but that will make the angle equal to over 180 degrees, so i am confused on what i am supposed to do.1. The speed of the hour hand is the distance it goes divided by the time so
2*pi*r /(60*60)=v
v=7.6x10^-3 cm/s
2. the velocity of the given time is the magnitude of the speed so it is the same number but the i can't find the angle
V=7.6x10^-3 [some angle]
3. ∆v=(vf-vi)
∆v=(7.6x10^-3)^2+(-7.6x10^-3)^2-2(7.6x10^-3)(-7.6x10^-3)cos103.9
∆v=8.8x10^-5 cm/s
Its mostly the angle on what i am confused about
When the clock is at 3:00:00 exactly, the hands will appear like this: L
When the time is 3:27:49, I don't think the clock hands make the triangle as shown in your attachment.
this.
x= tan-1 (15/15)
x=45 degree
I'm not sure what you are doing here, but you can't treat this triangle like it was a right triangle. You have an oblique triangle, so you've got to use the law of sines or the law of cosines to figure out the missing information about the triangle.
Thank you so much, I completely forgot about that. I found the angles and the answers to the problem
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 21 ·
