Capacitance homework problem help
Capacitance behaves as short-circuited when uncharged because the initial movement of charges requires minimal work, allowing current to flow freely. As the capacitor charges, an opposing electric field develops, increasing the work needed to move additional charges. Once fully charged, the electric potential between the capacitor plates equals the applied voltage, resulting in zero current flow, akin to an open circuit. The transition from short circuit to open circuit occurs rapidly during the charging process, where the current spikes momentarily before stabilizing at zero. Understanding these behaviors clarifies the dynamic nature of capacitors in electrical circuits.
ranju
Why capacitance behaves as shortcircuited in uncharged state and why as open circuited when its fully charged..?? I am reallt doubtful..:confused:
i=Cdv/dt...so if we r appyling a dc voltage ..in that case i should be zero.>! thn why short-circuited..??
A capacitor stores electrical energy by moving charges off of one plate and onto the other. Initially each plate is electrically neutral, just like a normal conductor, so the first few charges require very little work to move and current flows as if the capacitor were short circuited. As more and more charges are moved from one plate to the other, an electric field develops that opposes the voltage source, meaning that each additional charge requires more work to move. When the electric field is equal to the applied voltage, there is no longer any difference in electric potential (voltage) between the voltage source and the plates so you have no more current flow, just like an open.
Does that help?
Likes 1 person
Well for example when we charge a capacitor with a voltage source V via a resistance R, then we have from kirchhoffs Voltage Law
V-I*R-q/C=0 (1).
When the capacitor is uncharged then q=0 the term q/C is also zero, hence what is left from (1) is V-IR=0, it is like the capacitor has been short circuited (or it doesn't exist).
When capacitor is fully charged then q=C*V hence from (1) follows that -I*R=0 thus I=0, it is like the circuit is open and no current can flow.
i=0 in the steady state. Before the steady state, there will be a transient state of time dt where the current has very high value (theoretically infinite ) and it charges the capacitor very rapidly (within time dt) to final charge q=C*V. So again the capacitor passes from the "short circuit" stage where the current is very high to the open circuit stage where the current is zero.
Likes 1 person
Drakkith..and Delta your ans. is quite helpful. thanxx..
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
