Capacitance in series and parallel circuit
The discussion focuses on calculating the equivalent capacitance between two points in a circuit with multiple capacitors. It clarifies that the 4 µF and 12 µF capacitors are in parallel, yielding a combined capacitance of 16 µF. The 24 µF, 12 µF, and 8 µF capacitors are identified as being in series, which affects the overall calculation. The importance of identifying series and parallel configurations correctly is emphasized, as incorrect assumptions can lead to faulty calculations. The conversation concludes with a recommendation to approach the problem step by step, identifying and replacing combinations of capacitors methodically.
thatgirlyouknow
[SOLVED] Capacitance in series and parallel circuit
Determine the equivalent capacitance between A and B for the group of capacitors in the drawing.
Cseries = 1/Cs = 1/c1 + 1/c2 + ...
Cparallel = Cp = C1 + C2 + ...
The 4 and 12 micro farad capacitors are in parallel, so Cp = 16mf.
The other four are in series, so 1/5+1/24 = 1/C = 4.138mf (top)
1/6+1/8 = 1/C = 3.429mf (bottom)
All of these are in series, so 1/4.138+1/3.429+1/16 = 1/c; c = 1.678mf
This is not right. Where is my logic faulty?
The 24 uF, 12 uF and 8 uF capacitors are in series - since they are end to end between the two nodes in common with the 4 uF capacitor.
So find the capacitance of the series of 24 uF, 12 uF and 8 uF, and that combination is parallel with the 4 uF capacitor. That group is in series with the 5 uF and 6 uF capacitors between nodes A and B.
Capacitors are in parallel only if their ends are directly connected by nothing but a wire. That's not the case here, since the 24 and 8 micro farad capacitors are in the way.
Similarly, capacitors are in series only if there's nothing else in the path.
Do it step by step. Find the obvious combinations and replace them with their equivalents. Then redraw it, looking for more combinations.
The first combination that I see are several capacitors in series. Start there.
Thanks guys; apparently I didn't quite understand how to combine initially. I get it now!
