Capacitance in series and parallel circuit
3 replies · 18K views
thatgirlyouknow
[SOLVED] Capacitance in series and parallel circuit
Determine the equivalent capacitance between A and B for the group of capacitors in the drawing.
Cseries = 1/Cs = 1/c1 + 1/c2 + ...
Cparallel = Cp = C1 + C2 + ...
The 4 and 12 micro farad capacitors are in parallel, so Cp = 16mf.
The other four are in series, so 1/5+1/24 = 1/C = 4.138mf (top)
1/6+1/8 = 1/C = 3.429mf (bottom)
All of these are in series, so 1/4.138+1/3.429+1/16 = 1/c; c = 1.678mf
This is not right. Where is my logic faulty?
The 24 uF, 12 uF and 8 uF capacitors are in series - since they are end to end between the two nodes in common with the 4 uF capacitor.
So find the capacitance of the series of 24 uF, 12 uF and 8 uF, and that combination is parallel with the 4 uF capacitor. That group is in series with the 5 uF and 6 uF capacitors between nodes A and B.
Capacitors are in parallel only if their ends are directly connected by nothing but a wire. That's not the case here, since the 24 and 8 micro farad capacitors are in the way.
Similarly, capacitors are in series only if there's nothing else in the path.
Do it step by step. Find the obvious combinations and replace them with their equivalents. Then redraw it, looking for more combinations.
The first combination that I see are several capacitors in series. Start there.
Thanks guys; apparently I didn't quite understand how to combine initially. I get it now!
