How Long Does It Take to Charge a 195 µF Capacitor to 125 Volts?
To charge a 195 µF capacitor to 125 volts with a current of 3.71 mA, the charge (Q) is calculated using the formula Q = CV, resulting in 24.3 mC. The initial attempt to find the time (t) using the equation Q = 1 - e^(t/rc) was incorrect due to misunderstanding the nature of the current. Instead, the correct approach is to use Q = IT, leading to the formula t = Q/I. This calculation yields a charging time of approximately 6.55 seconds. The discussion highlights the importance of using the appropriate equations for constant current scenarios.
boneill3
In a camera flash unit, a capacitor is charged up over a period of several seconds (from a battery). The capacitor is discharged very rapidly -- in about 1 millisecond -- into a gas tube producing a very brief, bright flash of light. How long will it take to charge a 195 µF capacitor to a potential difference of 125 volts with a current of 3.71 mA? Answer in seconds.
I was given a hint to solve for Q first.
Q= CV
Q= 1-e^(t/rc)
FIrst I calculated Q= CV to be 195 µF * 125v = 24.3 mC
than I used ohms law to R= V/I = 33.693Kohms
Than I put those values into Q= 1-e^(t/rc)
and solved for t which gave me 162 msec
which was incorrect so I'm note sure where I am going wrong
any pointers?
In this problem the current is constant and not exponential. So you have simply
Q = IT
Thanks mate your a ledgend
Q = IT solve for t = Q/I t = 6.55 seconds
