Design a 4.50e-7 C Capacitor w/ 220V & 0.375 m2 Plates
  • Thread starter Thread starter purduegirl
    Capacitor Design
To design a capacitor that stores 4.50 × 10^-7 C with a 220 V power supply and 0.375 m² plates, the maximum plate separation must be calculated. The relevant equation is V = Q*d/(A*ε₀), where ε₀ is the permittivity of free space. A participant calculated the plate separation (d) as 1.62E-2 m but expressed uncertainty about the accuracy. Another participant suggested recalculating and verifying the equation and values used in the calculation. Accurate calculations are essential for determining the correct plate separation in capacitor design.
purduegirl
You must design a capacitor capable of storing 4.50 × 10-7 C of charge, but you only have a 220- V power supply and two metal plates of area 0.375 m2 each. What is the largest value the plate separation can be so that you can accomplish the task?
V = Q*d/A*epilson 0
I solved for d, and got 1.62E-2 m. Again, don't know what I am doing wrong here.
Hi purduegirl,
That's not quite the answer I get from your equation. Why don't you calculate it again; if you still get the same thing, please show what equation you got when you solved for d and then exactly the numbers you plugged in your calculator.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
