Carnot Refrigerator Efficiency and Energy Calculations | Homework Help
An ideal refrigerator operating on a Carnot cycle between 0 and 25 degrees Celsius is analyzed for its efficiency and energy calculations. To convert 10 kg of water at 0 degrees Celsius into ice at the same temperature, the heat exhausted into the room and the energy supplied to the refrigerator must be determined. The coefficient of performance (COP) is defined as the ratio of heat removed from the cold reservoir to the work input. The relationship between the heat quantities (Qh and Qc) and work (W) is crucial for solving the problem. Understanding these equations is essential for calculating the required values accurately.
lindsey4
An ideal refrigerator utilizes a carnot cycle operating between 0 and 25 degrees celsius. To turn 10 kg of water at 0 degrees celsius into 10 kg of ice at 0 degrees celsius,
a) how much heat is exhausted into the room?
b) how much energy must be supplied to the refrigerator?
coefficient of performance of carnot refrigerator (Kcarnot): Tc/(Th-Tc)
n (funky n for efficiency thing)=Wout/Qh [but isn't that for engine]
K=Qc/W
I'm guessing part A is Q so I'd have to find that somehow. And, for part B I think you use the last formula I put here and input Q to find W.
An ideal Carnot cycle is reversible, so W is the work, whether it's in or out.
The only thing that changes is how efficiency is defined. Equations not involving η are unchanged.
W = QH (1-TC/TH ) = QC (1-TH/TC )
There are two Qs: QH and QC. Which do you want for part A?
K=Qc/W
The COP for the refrigerator is output/input where the output is the amount of heat removed from the cold reservoir, Qc and W is the work supplied: COP = Qc/W
Since W = Qh-Qc, and Th/Tc = Qh/Qc, you can express COP in terms of Th and Tc (your expression is correct).
For a) what do you need to find? (hint: it is one of W, Qh or Qc). For b) what do you need to find? (same hint)
AM
