Cartesian to cylindrical coordinates (integration question)
Miike012
There has been a few times when I switch from Cartesian to cylindrical coordinates to integrate I would get the wrong because I used the wrong substitution.
For instance I would use x = rcos(θ) and y = rsin(θ) where r and θ are variable when I was suppose to leave r as a constant.
Question: correct me if I am wrong, I should use x = rcosθ and y = rsinθ where r is variable if the cross section parallel to my region of integration are circles whose radius are not constant. For example: a cone.
And I would choose r to be the appropriate constant if the cross sections are circles with constant radius for example the surface x^2 + y^2 = 16 ... a cylinder.
Is there anything else I should know?
A surface requires two parameters while curve requires only 1. For example, to describe the unit circle ##x^2+y^2=1## and its interior you could use ##x=r\cos\theta,\, y=r\sin\theta## where ##r## varies from ##0## to ##1## and ##\theta## varies from ##0## to ##2\pi##. If you just set ##r=1## then you just get the curve enclosing the area. If you set ##\theta = \pi/4## and let ##r## vary you get the ##45^\circ## line.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
