What speed does a cat's tail need to rotate for a safe landing?
  • Thread starter Thread starter vabamyyr
    Falling Tree
The speed at which a cat's tail must rotate for a safe landing is influenced by factors like fall height and angle. In an 8-meter drop scenario, a cat would need to achieve approximately 10 rotations per second to land on its feet, based on its body and tail's moments of inertia. This calculation relies on the principle of conservation of angular momentum, as the cat's body has a higher moment of inertia. However, this estimate does not account for air resistance or the cat's reflexes, which are critical for adjusting tail rotation during a fall. Ultimately, while the calculation provides a rough guideline, actual tail rotation can vary with circumstances.
vabamyyr
cat is climbed to the branch, holding to it with its paws. Cat is 8 m from ground. It starts falling. The question is that how fast must he rotate its tail for him to land on feet? Moment of inertia of its body is 50 000 g*cm^2 and moment of inertia oh his tail is 5 000 g*cm^2.
ok, i found it out,
The speed at which a cat's tail needs to rotate for a safe landing depends on a variety of factors, such as the height from which the cat is falling and the angle at which it is falling. In this specific scenario, where the cat is 8 meters from the ground and has a moment of inertia of 50,000 g*cm^2 for its body and 5,000 g*cm^2 for its tail, the cat would need to rotate its tail at a higher speed in order to safely land on its feet.
Without knowing the angle of the fall, it is difficult to determine the exact speed at which the cat's tail would need to rotate. However, based on the given information, we can make some estimations. If we assume that the cat is falling straight down and that its tail is able to rotate freely, the cat would need to rotate its tail at a speed of approximately 10 rotations per second (rps) in order to land on its feet safely.
This calculation is based on the conservation of angular momentum, which states that the total angular momentum of a system remains constant unless an external torque is applied. In this case, the cat's moment of inertia is significantly higher for its body compared to its tail, meaning that its body would have a greater tendency to rotate. By rotating its tail at a high speed, the cat can counteract this rotation and land on its feet.
However, it is important to note that this is a simplified calculation and does not take into account other factors such as air resistance and the cat's ability to adjust its tail rotation during the fall. In reality, a cat's instincts and reflexes play a crucial role in its ability to land safely on its feet. So while the calculated speed may provide a general estimate, a cat's actual tail rotation may vary depending on the specific circumstances of the fall.
