Center of mass of the human figure
The discussion revolves around calculating the center of mass of a human figure in a sitting position, broken down into three parts: torso, upper legs, and lower legs. Participants emphasize the importance of using the center of mass equation, Xcm = (m1x1 + m2x2 + ...)/(m1 + m2 + ...), to find both x and y coordinates. A common misconception is clarified that the torso, neck, and head also have an x-coordinate, which is zero since they are on the y-axis. Additionally, it is noted that any values below the origin should be treated as negative. The conversation concludes with a participant successfully grasping the concept and expressing appreciation for the forum's help.
shaka23h
The drawing shows a human figure approximately in a sitting position. For the purposes of this problem, there are three parts to the figure, and the center of mass of each one is shown in the drawing. These parts are: (1) the torso, neck, and head (total mass = 41.5 kg) with a center of mass located on the y-axis at a point 0.359 m above the origin, (2) the upper legs (mass = 15.2 kg) with a center of mass located on the x-axis at a point 0.153 m to the right of the origin, and (3) the lower legs and feet (total mass = 9.06 kg) with a center of mass located 0.478 to the right of and 0.299 m below the origin. Find the (a) x coordinate and (b) the y coordinate of the center of mass of the human figure. Note that the mass of the arms and hands (approximately 12% of the whole-body mass) has been ignored to simplify the drawing.
I can't submit the drawing, but I'm really stumped on this problem. Perhaps some kind of hint to get me started? I know how to find the center of mass of something but the X and Y coordinates? Help!
Don't you apply the "seesaw principle"? Fulcrumology?
A 1 pound weight, 2 feet from the fulcrum will be balanced by a 2 pound weight 1 foot from the fulcrum.
I've never heard of that before. The only equation that I could use is Xcm = m1x1 + m2x2.../ m1 + m2... how would I apply it though :(
Thanks
That's exactly the equation you need. You have the coordinates and mass of each piece. Use that equation to find the x and y coordinates of the center of mass of the entire body. (You'll need to apply it twice, once for x-coordinates, once for y-coordinates.)
ok this is what I have so far.
Xcm = (15.2)(.153)+ (9.06)(.478)/ (15.2 + 9.06) From this I got .27437. I've submitted this answer for online grading and its not it... I get a total of 5 tries.
Ycm = (15.2)(.153)+ (9.06)(.478) / (15.2+ 9.06)
Doc you have any clue what I'm doing wrong?
Thanks
You left out one of the pieces! You forgot the "torso, neck, and head". (The "+ ..." in the center of mass equation indicates that you keep on adding terms for all the pieces... m1, m2, m3, m4, whatever. In this problem, you have three pieces to consider so you must extend the equation appropriately.)
First thing for you to do: Write out the center of mass equation for three pieces.
http://img230.imageshack.us/img230/1766/ch07p44rl1.gif
here is the image of the actual problem
the reason I didn't added the head is because I didn't think there is a x cordinate for it? it just says center of mass located on the y-axis at a point .39 m above the origin. Where is the x coordinate for this? Also I'm wondering if the value is below the orgin does this make it a negative value?
Thanks a lot Doc
Of course it has an x coordinate, just like any other point. Hint: Every point on the y-axis has the same x coordinate. What is it?
Absolutely.
wow I GOT it!
you are awsome.
Thanks a lot Doc I love this forum !
