Center of Mass Calculation for a Club-Axe: How Far from the Handle is the COM?
The discussion revolves around calculating the center of mass (COM) of a club-axe, which consists of a 23.0 kg stone and a 2.8 kg stick. The initial attempt at the calculation resulted in an incorrect answer of 101.59 cm, while the correct COM is 91.9 cm from the handle end. Key errors included misunderstanding the positions of the center of gravity for both the handle and the stone. The importance of using the correct coordinates for the COM calculation is emphasized, as well as the need for proper parentheses in the equation. Accurate placement of mass along the lengths of the handle and stone is crucial for determining the correct COM.
michaeltozer13
A club-axe consists of a symmetrical 23.0 kg stone attached to the end of a uniform 2.8 kg stick. The length of the handle is L1=91.0m and the length of the stone is L2=13.0cm. How far is the center of mass from the handle end of the club?
Center of mass equation: COM=x1m1+x2m2/(m1+m2)
so for my attempt i kept the lengths in cm, and my equation looks like this COM=(91.0x2.8)+(104x23.0)/(2.8+23.0).
The answer I am getting is 101.59 cm, which is wrong. The correct answer is 91.9cm. Any help??
x1 isn't the length of the handle: it's the position of the center of gravity of the handle !
Likewise, x2 isn't the end of the stone but the x coordinate of the center of mass of the stone.
I do hope the glue at the end of the handle is strong enough :)
welcome to the world of PF !
I assume you mean ((91.0x2.8)+(104x23.0))/(2.8+23.0) (parentheses matter!)
That would be right if all of the mass of the stick were at 91cm from the end, all the mass of the stone at 104cm from the end. But they're not.
That's a very long handle!
