Central Force Field: Meaning of Centrifugal Term
In the context of motion within a Central-Force Field, the term 'centrifugal' refers to an effective potential energy that depends solely on the radius r. This term arises from the relative force expressed as (-grad) and is often misunderstood as a real force. Some participants in the discussion argue that 'centrifugal force' is a misnomer, as it is not a true force but rather a perceived effect in a rotating reference frame. The effective potential includes a term, + L^2/(2mr^2), which suggests an outward-directed force associated with the orbit. Overall, the discussion clarifies the conceptual understanding of centrifugal effects in inertial frames.
rob60
In the study of motion in a Central-Force Field in radial coordinates it is defined an effective potential energy which depends only on the radius r: in particular there is a term 'centrifugal' because the relative force (-grad) has a centrifugal versus. What is the meaning of this expression since it is derived from an inertial frame?
thank you
thank you
Some key words in your post are missing or incorrect, as it makes no sense as it stands?
I'm sorry but I do not understand what are the errors. thanks for the help
What is a centrifugal versus?
And I don't think you should be using the term centrifugal anyway! The is no such thing as a centrifugal force!
oh yes. My english is inadequate: excuse me, please.
the 'effective potential expression' has a term: + L^2/(2mr^2).
The force associate is directed outward from the center of the orbit, it looks like a 'centrifugal force'.
