Centripetal force and acceleration problem
The problem involves a car traveling along a circular track, with specific parameters including mass, radius, and acceleration. The focus is on determining the car's tangential velocity after covering a quarter of the track's distance.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss how to approach the problem by separating magnitude and direction, and converting acceleration units. There is also an exploration of using constant acceleration formulas to find the final speed.
Some guidance has been provided regarding the conversion of acceleration units and the calculation of distance for a quarter circle. Participants are actively engaging with the problem, but no consensus has been reached on the overall approach.
Participants note the challenge of determining the period of rotation and the specifics of calculating distance for a quarter of the circular track.
ScienceGirl90
A 2500 kg car starts from rest and travels along a circular track with a radius of 55.0 meters. The car starts out at a position due East of the center of the track, heading due North initially around the track, which is counterclockwise. The car increases its speed by 105 m/s every minute around the track. How fast is the car traveling when it is 1/4 of the distance around the track? State the car's tangental velocity.
v=2*pi*r/period
I am unsure of how to begin this problem when I'm looking for only 1/4 of the distance. I'm also having a hard time finding the period of one full rotation around the track. Any help would be appreciated! Thanks.
In this case you are better off doing the magnitude and the direction separately. Figure out the distance for the quarter circle and translate the "105 m/s every minute" into an acceleration in m/s. Then treat it like a linear motion problem and just use your constant acceleration formulas to find the final speed.
Ok, thank you. Would you mind explaining how I get 105 m/s every minute to m/s for acceleration?
105m/s per minute translates to an acceleration a = of 105/60 = 1.75 m/sec/sec
To cover 1/4 th the circumference of a circle of radius is (1/4) * 2 * pi * r
this gives the distance "S"
Now use the formula velocity after covering S is =
V*V = 2* a * S
