To calculate centripetal force in pendulums, start with a free body diagram for clarity. The formula used is F_c = m(v^2/R), where R represents the pendulum's length. It's essential to know the speed of the pendulum, which can be determined using conservation of energy principles. Understanding these concepts is crucial for accurate calculations. Proper application of these methods will enhance your analysis of pendulum motion.
#1
duoheer
How do you calculate the centripetal force in pendulums?
THx
THx
You use F_c = m {v^2 \over R} where R is the radius of the circle which is the length of the pendulum. You have to be given the speed or to find it using conservation of energy.
Kindly see the attached pdf. My attempt to solve it, is in it.
I'm wondering if my solution is right. My idea is this: At any point of time, the ball may be assumed to be at an incline which is at an angle of θ(kindly see both the pics in the pdf file). The value of θ will continuously change and so will the value of friction.
I'm not able to figure out, why my solution is wrong, if it is wrong .
TL;DR Summary: I would like to know the voltmeter readings on the two resistors separately in the picture in the following cases , When one of the keys is closed When both of them are opened (Knowing that the battery has negligible internal resistance)
My thoughts for the first case , one of them must be 12 volt while the other is 0
The second case we'll I think both voltmeter readings should be 12 volt since they are both parallel to the battery and they involve the key within what the...
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h.
So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
