Centripetal Force Lab: Calculate Proportionality & Plot Data
The discussion focuses on calculating proportionality and plotting data related to centripetal force. The user seeks guidance on rearranging frequency data to achieve a straight line when graphed. They mention a previous lab experience with period versus force, noting that frequency is the inverse of the period. A suggestion is made to plot T against 1/sqrt(force) to linearize the graph. Additionally, there is clarification on the meaning of frequency expressed as 10 s^-1, confirming it represents 10 cycles per second or 10 hertz.
F.B
I need help with a question on my lab, I am used to finding proportionality statements between sets of data and graphing it to get a straight line. But this question is different. Anyways here's the data i have. Oh you the lab is on Centripetal Force
frequency/Force
1.02 / 5
1.33 / 10
1.65 / 15
1.87 / 20
The slashes just separate the numbers so they don't bunch up.
Here the question i need help on.
Rearrange the data for the frequency in such a manner as you think will result in a straight line when plotted. Plot this data on graph paper#2. What is the equation for this relationship by calculating the constant of proportionality.
I just did a lab like this a few days ago, although I am sure I did a terrible job :-p
I did not do frequecy, I did period vs. force, but frequency is 1/T, so it should not be terribly different. You must first manipulate your centripetal force formula in such a wat that you have insolated your term(s) for frequency, then you will be able to work out a mathematical relationship, which for me was T is inversely proportional to the root of ceptripetal force. Rather than plotting my graph T vs. Force, I plotted it as T vs. 1/sqrt(force), which straightens your graph.
another quick question. If in one of the questions it says the frequency is 10 s^-1 what does that mean? does it mean??
10 cycles per second, or 10 hertz. Raising a unit to the negative one is a fancy way of putting it in the denominator.
