Change in internal energy of a gas
The discussion focuses on calculating the change in internal energy (dU) of two moles of carbon monoxide (CO) during an adiabatic compression from a volume of 30 liters to 10 liters at an initial pressure of 1.2 atm. The relevant equations include the first law of thermodynamics, Q = dU + W, and the ideal gas law, PV = nRT. The specific heat capacity at constant pressure (Cp) is given as 29.16 J/(mol * K). The solution requires determining the initial temperature (T1) and the final temperature (T2) using the adiabatic process equation TV^γ = constant.
  • Understanding of the ideal gas law (PV = nRT)
  • Knowledge of adiabatic processes and the equation TV^γ = constant
  • Familiarity with the first law of thermodynamics (Q = dU + W)
  • Concept of specific heat capacity (Cp) for gases
  • Calculate initial temperature (T1) using the ideal gas law with given pressure and volume
  • Determine final temperature (T2) using the adiabatic process equation TV^γ = constant
  • Calculate work done (W) during the adiabatic compression
  • Compute the change in internal energy (dU) using dU = nCpdT
Students studying thermodynamics, particularly those focusing on gas laws and energy transformations in adiabatic processes.
6021023
Two moles of carbon monoxide (CO) start at a pressure of 1.2 atm and a volume of 30 liters. The gas is then compressed adiabatically to 1/3 this volume. Assume that the gas may be treated as ideal.
What is the change in the internal energy of the gas?
n = 1.2 atm
V2 = 10L
V1 = 30L
Cp = 29.16 J/(mol * K)
Q = dU + W
dU = dQ - dW
dU = nCpdT - pdV
dT is not known, and I can't go any further.
You can find [tex]T_1[/tex] using PV = nRT. You can then use the adiabatic equation [tex]TV^{\gamma}= constant[/tex] to find [tex]T_2[/tex]
