How Do You Calculate the Change in Internal Energy for Hydrogen Gas?
To calculate the change in internal energy for one mole of hydrogen gas heated from 278 K to 390 K at constant pressure, the formula used is ΔU = (1.5)nRT, where n is the number of moles, R is the universal gas constant, and T is the change in temperature. The calculation performed yielded a result of approximately 1396.84 J. However, the student is unsure why this answer is marked incorrect, suspecting it may relate to significant figures, despite being instructed to maintain five decimal places. The discussion highlights confusion over the application of significant figures and the correct interpretation of the formula. The student seeks clarification on the calculation process and potential errors.
alexithymia916
One mole of hydrogen gas is heated from 278 K to 390 K at constant pressure. Hydrogen has a specific heat of 43.6 J/mol*K. The universal gas constant is 8.31451 J/K mol. Calculate the change in the internal energy of the gas. Answer in units of J
Change in Internal energy = (1.5)nRT
n= number of moles
R= universal gas constant
T= change in temperature
(1.5)(1 mol)(8.31451 J/k mol)(112 K)
1396.83768
what am i doing wrong??
the website i have to submit my homework to says it's incorrect...:eek:
I think that's right... You may want to look at the significant figures though.
noo def not
my teacher HATES significant digits, so we're just supposed to carry it out about 5 decimal places
grr i can't figure this one out :(
