How Does Jet Engine Thrust Affect Train Kinetic Energy?
The discussion focuses on calculating the work done on an experimental train powered by a jet engine, which produces a thrust of 5.00 x 10^5 N over a distance of 509 m. The work done on the train is calculated as 2.545 x 10^8 J, which directly relates to the change in kinetic energy, confirming that the work done results in an increase in kinetic energy. The train's final kinetic energy can be determined using the work-energy principle, and the final speed can be calculated by first finding acceleration from the thrust and then applying kinematic equations. The conversation emphasizes ignoring frictional forces for these calculations. Overall, the relationship between thrust, work, and kinetic energy is central to solving the problem.
citypigeon
In the 1950s, an experimental train that had a mass of 2.50 x 10^4 kg was powered across the level track by a jet engine that produced a thrust of 5.00 x 10^5N for a distance of 509m.
a)Find the work done on the train
b)Find the change in kinetic energy
c)Find the final kinetic energy of the train if it started from rest
d)Find the final speed of the train if there were no friction.
a)
W=fd
W= (5.00 x10^5N)(509m) = 2.545 x 10^8
b)
I'd typically find the change in KE when I have differences in velocity b/c of the equation KE=(1/2)mv^2, but I don't have v in this equation and I don't know how to find it when I don't have time (t).
I know KE changes when there is change in height, but the train runs on a level track, does that mean there is none?
Then in my review book it says W= KE initial - KE final = change in KE
Does that mean the work I found done on the train is the same as the change in KE involved? I don't know...
c)
I used v(f)^2 = v(i)^2 = 2ad
v(f)^2= 2(9.8)(509)
=99.88
d)
I really don't know how to approach this one...
Likes salma-2022
Answer is the same for a,b and c.
For (d), find acceleration a = thrust / mass
then use the formula v(f)^2 = v(i)^2 + 2ad to find v(f)
Likes salma-2022
Welcome to PF.
Yes the work done will result in an increase in kinetic energy.
The problem generally wants you to ignore frictional forces.
Likes salma-2022
