Change of Variables in Multple Integrals
number0
Let D be the region y \leq x \leq 1 and 0 \leq y \leq 1.
Find the boundaries of the integration for the change of variables u and v, if:
x = u + v and y = u-v.
None
I solved for u and for v in terms of x and y.
u = \frac{x+y}{2}
v = \frac{x-y}{2}
Then I got stuck.
The book answer's is:
v \leq u \leq 1-v and 0 \leq v \leq 1/2Can anyone show me how to figure this problem out without any reference to graphing (just
pure algebraic)?
None
u = \frac{x+y}{2}
v = \frac{x-y}{2}
Then I got stuck.
pure algebraic)?
Why do you guys always like to make things more difficult for yourself by refusing to draw a picture?
Just rewrite the boundaries of D in terms of u and v. For example,
y \le x \Rightarrow u-v \le u+v \Rightarrow 0 \le 2v \Rightarrow v \ge 0
Well, I did that part already. However, how is it possible to get v \leq 1/2 (the
book's answer). For example,
x \leq 1 => u + v \leq 1 => v \leq 1 - u
Which is supposedly not equivalent to v \leq 1/2
How would you go about solving the other ones (v \leq u \leq v-1) ?
You need to do the third side of D, y≥0. When you combine it with what you got for x≤1, you can get that upper limit for v.
Okay, can you explain it a bit more. Sorry about being unknown about what you mean, but I
think if I finally understand what you are trying to say, I can finally get this problem correct.
y≥0 translates to u≥v, and x≤1 gave you u≤1-v. Combining those, you get v≤u≤1-v. (You almost had this above, but you flipped a sign.) You can't have v=1, for instance, because you'd get 1≤u≤0. What restriction on v must exist for those inequalities to be satisfied?
Now, I think I am starting to get it. I think I am having a conceptual misunderstanding of the
situation at hand! I am elated that you pointed out how I flipped the sign. Here is the reason
why I flipped the sign:
y \leq 1 => u - v \leq 1 => u \leq 1 + v (correct answer: u \leq 1 - v)
Can you tell me why this would not work?
That is valid, but it doesn't help much. Another constraint gave you v≥0, so if u≤1-v holds, u≤1+v automatically holds as well.
