Changing the RPM of a frictionless spinning wheel in a box
The discussion revolves around the behavior of a frictionless spinning wheel within a vacuum box, specifically focusing on whether the RPM of the wheel can be changed through external manipulation of the box. The scope includes conceptual reasoning and mechanical principles related to rotational motion.
  • One participant suggests that the wheel will continue to rotate as if in space and that the RPM cannot be changed without breaking the box or its contents.
  • Another participant questions the attachment of the wheel axle to the box and the role of gravity in the scenario.
  • A participant draws an analogy with a bike wheel, proposing that turning the handlebars does not change the RPM of the wheel if there is no friction.
  • Another response supports the idea that in an ideal case with no axial friction, the RPM would remain unchanged, suggesting that conservation principles may apply.
  • One participant emphasizes the necessity of assuming that the wheel is balanced for the discussion to hold.
Participants express differing views on the influence of external manipulation on the RPM of the wheel. While some agree that RPM remains constant under ideal conditions, others raise questions about the assumptions involved, indicating that the discussion remains unresolved.
Participants note the importance of assumptions such as the absence of friction and the balance of the wheel, which may affect the conclusions drawn from the discussion.
SpaceThoughts
Imagine a spinning wheel built into a hand size vacuum box. There is no friction between the axe bearings of the wheel and the box. Let's say that the wheel rotates with 60 RPM. Am I right if I assume:
1. The wheel continues to rotate, approximately as if in space.
2. It is not possible to change the 60 RPM in any way, as long as the box and the content is not broken. No matter how we twist and turn the box from the outside.
How is the wheel axle attached to the interior of the box? How does gravity play in all of this?
Also, you can certainly design things to be able to add rotational energy to the spinning wheel, such as using a rotor from an electric motor as your spinning wheel...
Let me ask the same question in a less confusing way:
I lift the front wheel of my bike off the ground and make it spin. I turn the handlebars right-left-right-left.
I feel the resistance of moving the handlebar back and forth. The faster the wheel spins the more resistance.
Will turning the handlebar back and forth change the RPM of the bike wheel, or would the wheel continue to rotate with the same RPM if there were no friction?
From my experience I think the RPM would not change, but I have not found a clear answer to this question.
For the ideal case with no axial friction and, say, a perfectly rigid wheel your experience is correct. To see this you could perhaps ask yourself what mechanical quantity usually is conserved in cases of no friction and see if this helps you conclude something. This will also explain why the wheel, in addition to the axis bearings, has to be idealized (i.e. have no internal friction).
One needs the assumption that the wheel is balanced.
  • · Replies 60 ·
  • · Replies 22 ·
  • · Replies 35 ·
