Charge density in a resistor issue
8 replies · 4K views · last reply
oronanschel
given simple circuit with V the voltage connected to a resistor
with area A, length d and electrical conductance: b*e^-2x/d
after my computations the resistance
R=d*(e^2-1)/(2bA)
what is the electrical field E in the center of the resistor?
i think it must be 0 because i can't think of
why it will be charged
Hey,
Since you didn't provide any formulae, as to how you'd reached your result, let me ask you this: are you familiar with the relation: [tex]\sigma E = j[/tex]?(Local variation of Ohm's law) Where sigma is the conductance, and j is the current density.
Since the voltage is constant, E must be uniform, simple integration should yield what you're looking for...
I hope that helps somewhat,
Daniel
P.S
Clearly, by following the steps above, you can find that the density won't be zero, per se
The "continuity equation", however, if you recall, is still satisfied(naturally), and generates that equilibrium we all seek...
yeah..oops, this is the second question and I managed that one
I know the formula :
[tex]\sigma E = j[/tex](Local variation of Ohm's law)
the 3rd question was the charge density
that i couldn't figure out..
Have you tried Maxwell's equation->[tex]\overrightarrow{\nabla} \cdot \overrightarrow{E} = \frac{\rho}{\epsilon_0}[/tex]
Does that get you any closer?
Daniel
becasue E is E(x), can i say that
is
[tex]\frac{dE(x)}{dx} = \frac{\rho(x)}{\epsilon_0}[/tex]
then problem is solved
Absolutely! But of course, this could only work by stating that the area(A) is also only dependent on x... so long as that's maintained, you're prefectly correct.
Did you end-up reaching the desired answer?
I hope was I able to provide some aid,
Daniel
it doesn't say what is the correct answer but it satisfy me.
so any resistor is also charged (when connected to voltage)? sound weird to me
because out of symmetry why it would be charged positively
and not the opposite?
Since the current travels via a relative value known as the "drift velocity", the charges that encounter the most resistance will also tend to accumulate more in the region where that applies(where the resistivity is greater). This is a phenomenon which is typically observed, but in a different case, as "Skin effects":http://en.wikipedia.org/wiki/Skin_effect"
Be sure however to note that the most valuable equation for conserving the physical aspect of this problem, the "continuity equation" is left unchanged:
[tex]\overrightarrow{\nabla} \cdot \overrightarrow{j} = -\frac{\partial \rho}{\partial t}[/tex] which ensures the integrity of the solution.
I pray that shed some light on the issue at hand,
Daniel
