Charge on a point in three different locations with a thin semicircular rod
  • Thread starter Thread starter swagadoo
    Charge Point Rod
A thin semicircular rod is divided into two halves, with the top half carrying a charge of +Q and the bottom half a charge of -Q. The discussion focuses on determining the direction of the net electric force on a positive test charge placed at points A, B, and C. It is concluded that the horizontal components of the forces from the two halves cancel each other out, resulting in a net force directed straight down at all three points. The magnitude of the force varies with distance from the charges, being smaller at point A than at point B. Overall, the resultant force at points A, B, and C is consistently directed downward.
swagadoo
A thin semicircular rod is broken into two halves, the top half has a total charge +Q uniformly distributed along it, and the bottom half has a total charge -Q uniformly distributed along it.
http://imgur.com/tObt2V0
Indicate the direction of the net electric force on a positive test charge placed in turn at points A, B, C.
Had A's force vector pointing down and to the right, same with b and C pointing down and to the left but I am not sure about my answers.
Think about the forces in the horizontal and vertical directions separately. E.g. for A, compare the horizontal forces (i.e. along the line AB) exerted by the two quadrants.
I can't really visualize it but my guess is that the horizontal component of +Q would be to the left and the -Q would have a horizontal component equal and opposite so to the right. The vertical component of +Q on the charges would be down, same with the -Q charge.
Exactly so. So the resultant force is in which direction?
Down and to the right. Would it be the same for both A and B. And C would be down and to the right?
or is the resultant straight down?
If the horizontal components are opposite (and equal in magnitude, since all distances are the same for the + and for the - quadrant), don't they cancel each other?
yeah that's what I am thinking
Yeah, so the resultant is straight down, like you said :)
So all of the points; A,B, and C would have the same vector pointing down?
The magnitude of said vector would change according to distance from the point to the quadrants (i.e., the vector is smaller for point A than for point B), but it is indeed straight down for three points :)
Thank you very much.
